[petsc-users] SNES_DIVERGED_LS_FAILURE
Juha Jäykkä juhaj at iki.fi
Thu Jun 23 06:13:53 CDT 2011
> What physical system does it represent and what sort of discretization are
> you using?
Please see arXiv:0809.4303 for details. The equation is obtained from the
Lagrangian (4) by imposing cylindrically symmetric u with z and t appearing in
complex exponential in a certain way, which decouples z and t from the planar
variables. Furthermore, the angular variable vanishes (the whole point of the
ansatz), leaving one with just the equation for the radial profile of u. (This
is all similar to what is done in the article at Eq. (17), but the article has
further constraints imposed, which eventually gives exact solutions.)
After some rescaling of the domain and the codomain, one ends up with unknown
g:[0,1] -> [0,1], which is what I am solving.
> Do you know that the equations have a solution for all values of the
> parameter? Even simple problems may not have solutions for all values of a
Given the origin of the equation - a well defined Hamiltonian/Lagrangian, I
would be very surprised if there were no solutions. It is hard to prove,
either way, though. If I treat the problem as 3D energy minimisation one, I do
find solutions (of course I do: the energy is bouded from below!), which look
very much like what the diverged SNES line searches end up with, but not
quite. Therefore I believe there are solutions and end up with the theory I
explained in the original post.
Oh, now that the equations are there, the parameters I am scanning are the
product \beta e^2 and n, where n is comparable to the n in Eq (17). Obviously,
n is an integer so cannot be continued as such, but \beta e^2 is real, so I
start with \beta e^2 = 1, n=1, where the solution is g(y) = y.
Which reminds me of another oddity: if I start with the exact solution, my
function value is ~ 1e-11, so I know for sure to keep -snes_atol ~1e-10
because that's the best my function evaluation can do. Could this be the
problem? Too little accuracy in function? I did try up to 6th order central
differences, but it does not help.
Cheers,
-Juha
		| Juha Jäykkä, juhaj at iki.fi			|
		| http://www.maths.leeds.ac.uk/~juhaj		|
Name: not available
Desc: This is a digitally signed message part.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110623/b47f0a67/attachment.pgp>
