[petsc-users] SNES_DIVERGED_LS_FAILURE
Wed Jun 22 20:20:47 CDT 2011
On Wed, Jun 22, 2011 at 6:52 PM, Juha Jäykkä <juhaj at iki.fi> wrote:
> Hi all!
> I am having nasty problems with SNES. As you probably guess already, my
> result
> is non-converging line search. I have a good candidate reason for this, but
> I
> do not know how to fix it.
> Jacobian should be fine: -snes_ls_type test gives nice small numbers (not
> quite as small as I would like: around 1e-7).
> And even if Jacobian was wrong, -snes_fd behaves in exactly the same way.
> When snes gives up with its line search, the values in the residual vector
> are:
> 0.00000000e+00,   1.02404374e+00,   2.28558501e-01,
> 1.94195641e-02,  -4.82401091e-02,  -7.07456591e-02,
> -7.64790651e-02,  -7.55281623e-02,  -7.19176452e-02
> before they stabilise to interval (1.e-5, 8e-2). Now, my candidate is the
> huge
> (compared to others) value of the rhs at the second lattice point and
> slightly
> smaller, but still large at the third. The diverged solution vector grows
> very
> fast in the beginning and then settles to an almost constant value after
> about
> one tenth of the lattice, so my guess is that the big change needed at i=1
> causes precision to be lost at i>>1 and therefore line search fails.
> Do you have any ideas how to get around this or if my theory is even
> correct?
Its hard to say anything without knowing what equations are being solved.
However,
does the linear problem converge? If so, you could try continuation in a
parameter
in the nonlinear term.
   Matt
> Trying trust region search does not really help: it suffers from the same
> deficiency - except that it thinks it converges even though the function
> norm
> is of the order of 0.5. (It does fare slightly better, though, its rhs
> starts
> like
> 0.00000000e+00,   3.93745063e-01,   1.79187741e-01,
> 1.03100385e-01,   6.76686117e-02,   4.82967347e-02,
> 3.65243377e-02,   2.88059666e-02,   2.34452314e-02,
> which is better, but still not good enough.)
> Cheers,
> Juha
>                | Juha Jäykkä, juhaj at iki.fi                     |
>                | http://www.maths.leeds.ac.uk/~juhaj           |
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110622/3d652c8a/attachment.htm>
