[petsc-users] SNES_DIVERGED_LS_FAILURE
Juha Jäykkä juhaj at iki.fi
Wed Jun 22 18:52:09 CDT 2011
Hi all!
I am having nasty problems with SNES. As you probably guess already, my result
is non-converging line search. I have a good candidate reason for this, but I
do not know how to fix it.
Jacobian should be fine: -snes_ls_type test gives nice small numbers (not
quite as small as I would like: around 1e-7).
And even if Jacobian was wrong, -snes_fd behaves in exactly the same way.
When snes gives up with its line search, the values in the residual vector
are:
0.00000000e+00,   1.02404374e+00,   2.28558501e-01,
1.94195641e-02,  -4.82401091e-02,  -7.07456591e-02,
-7.64790651e-02,  -7.55281623e-02,  -7.19176452e-02
before they stabilise to interval (1.e-5, 8e-2). Now, my candidate is the huge
(compared to others) value of the rhs at the second lattice point and slightly
smaller, but still large at the third. The diverged solution vector grows very
fast in the beginning and then settles to an almost constant value after about
one tenth of the lattice, so my guess is that the big change needed at i=1
causes precision to be lost at i>>1 and therefore line search fails.
Do you have any ideas how to get around this or if my theory is even correct?
Trying trust region search does not really help: it suffers from the same
deficiency - except that it thinks it converges even though the function norm
is of the order of 0.5. (It does fare slightly better, though, its rhs starts
like
0.00000000e+00,   3.93745063e-01,   1.79187741e-01,
1.03100385e-01,   6.76686117e-02,   4.82967347e-02,
3.65243377e-02,   2.88059666e-02,   2.34452314e-02,
which is better, but still not good enough.)
Cheers,
Juha
		| Juha Jäykkä, juhaj at iki.fi			|
		| http://www.maths.leeds.ac.uk/~juhaj		|
Name: not available
Desc: This is a digitally signed message part.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110623/79fde707/attachment.pgp>
