[petsc-users] Optimized Option
zhenglun.wei at gmail.com zhenglun.wei at gmail.com
Fri Jun 3 15:28:44 CDT 2011
Thanks for your reply.
So, if I want to use '--with-debugging=0', what is the PETSC_ARCH equal to?
I just tried to use PETSC = arch-opt, and a error message comes up:
~/petsc-dev/conf/variables:95: ~/petsc-dev/arch-opt/conf/petscvariables: No
such file or directory
~l/petsc-dev/conf/rules:1018: ~/petsc-dev/arch-opt/conf/petscrules: No such
file or directory
make: *** No rule to make target `~l/petsc-dev/arch-opt/conf/petscrules'.
Stop.
this really confused me.
thanks,
Alan
On , Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jun 3, 2011, at 2:57 PM, Alan Wei wrote:
> > Dear Sir/Madam,
> > Lately, I read there is a optimized version of PETSc by
> using '--with-debugging=0'. I have two questions here:
> > 1, Do I need to use '/config/configure.py ... --with-debugging=0' when
> I configure the PETSc in order to use the non-debugging version of PETSc?
> Therefore, if I want to switch PETSc between these two versions, I have
> to keep configuring.
> ABSOLUTELY NOT. You use two different values of the environmental
> variable PETSC_ARCH and switch back and forth by changing the variable.
> You can even change it on the make command line. For example make mycode
> PETSC_ARCH=arch-opt
> Note that you can use any name you want for the values of PETSC_ARCH. I
> often use arch-debug and arch-opt to keep track of them.
> > 2, I was using the '--with-debugging=0' to configure the PETSc.
> However, I tested the computational rate by executing the ex29.c. The
> non-debugging version does not improve the speed much; in the contrary,
> it slow down the speed a little bit. The comparison is attached here. Any
> idea on this.
> It depends on the compiler and particular code you are running. We
> recommend using the option -log_summary to see how much time is spent in
> each part of the computation and how much it gets better with
> optimization.
> Barry
> > thanks in advance,
> > Alan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110603/a279288c/attachment.htm>
