[petsc-users] invalid object classid 0 between PETSc and SLEPc
Geoffrey Irving irving at naml.us
Wed Dec 28 14:48:37 CST 2011
On Wed, Dec 28, 2011 at 4:51 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 28 December 2011 01:16, Geoffrey Irving <irving at naml.us> wrote:
>> Hello,
>> I've installed PETSc 3.2 and SLEPc 3.2 on Mac OS 10.7 through MacPorts
>> 2.0.3.  PETSc works fine by itself, but SLEPc fails on the initial
>> EPSCreate call.  The error follows.
>> This is presumably a MacPorts misconfiguration issue, but thought I'd
>> check here first to see if anyone has seen this before in a similar
>> situation.  Only static libraries exist, so as far as I know the
>> suggested explanation doesn't apply.  The conf directory is at
>> http://naml.us/~irving/random/petsc-conf.tar.gz if it helps.
> Just in case, please run:
> $ otool -L ./your_executable
Seems clean.
tile:petsc% otool -L ../install/flavor/lib/libother_petsc.*
../install/flavor/lib/libother_petsc.dylib:
	/Users/irving/otherlab/other/install/debug/lib/libother_petsc.dylib
(compatibility version 0.0.0, current version 0.0.0)
	/usr/local/lib/OpenMesh/libOpenMeshCore.2.0.dylib (compatibility
version 2.0.0, current version 2.0.0)
	/usr/local/lib/OpenMesh/libOpenMeshTools.2.0.dylib (compatibility
	/opt/local/lib/libmpi_cxx.1.dylib (compatibility version 2.0.0,
current version 2.1.0)
	/opt/local/lib/libmpi.1.dylib (compatibility version 2.0.0, current
version 2.2.0)
	/opt/local/lib/libboost_iostreams.dylib (compatibility version 0.0.0,
	/opt/local/lib/libboost_filesystem.dylib (compatibility version
	/opt/local/lib/libboost_system.dylib (compatibility version 0.0.0,
	/opt/local/lib/libz.1.dylib (compatibility version 1.0.0, current
version 1.2.5)
	/opt/local/lib/libbz2.1.0.dylib (compatibility version 1.0.0, current
version 1.0.6)
	/opt/local/lib/libX11.6.dylib (compatibility version 10.0.0, current
version 10.0.0)
	/Users/irving/otherlab/other/install/debug/lib/libother_core.dylib
	/System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
(compatibility version 1.0.0, current version 4.0.0)
	/opt/local/Library/Frameworks/Python.framework/Versions/2.6/Python
(compatibility version 2.6.0, current version 2.6.0)
	/usr/lib/libstdc++.6.dylib (compatibility version 7.0.0, current
version 52.0.0)
	/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current
version 159.1.0)
../install/flavor/lib/libother_petsc.so:
version 159.1.0)
I forgot to mention that I'm linking both petsc and slepc into an
.dylib and then into an .so which is then dynamically loaded as a
python module.  Since both petsc and slepc are linked as static
libraries into the .dylib but not the .so, there shouldn't be any
issues with shared library boundaries, but I could be wrong about
this.  The link commands are
g++ -o build/nocona/release/petsc/libother_petsc.dylib -install_name
/Users/irving/otherlab/other/install/release/lib/libother_petsc.dylib
-dead_strip -fvisibility=hidden -dynamiclib
build/nocona/release/petsc/ksp.os build/nocona/release/petsc/module.os
build/nocona/release/petsc/slepc.os build/nocona/release/petsc/util.os
-L/opt/local/lib/petsc/lib -L/usr/local/lib/OpenMesh -L/opt/local/lib
-Linstall/release/lib -lOpenMeshCore -lOpenMeshTools -lmpi_cxx -lmpi
-lslepc -lboost_iostreams -lboost_filesystem -lboost_system -lz -lbz2
-lpetsc -lX11 -lother_core -F/opt/local/Library/Frameworks -framework
Accelerate -framework Python
gcc -o build/nocona/release/petsc/libother_petsc.so -dead_strip
-fvisibility=hidden -bundle -L/opt/local/lib/petsc/lib
-L/usr/local/lib/OpenMesh -L/opt/local/lib -Linstall/release/lib
-F/opt/local/Library/Frameworks -framework Accelerate -framework
Python
> Do you have any other PETSc/SLEPc build lying around?
I do, but they didn't show up in my environment variables.
Geoffrey
