[petsc-users] invalid object classid 0 between PETSc and SLEPc
Lisandro Dalcin dalcinl at gmail.com
Wed Dec 28 07:51:55 CST 2011
On 28 December 2011 01:16, Geoffrey Irving <irving at naml.us> wrote:
> Hello,
> I've installed PETSc 3.2 and SLEPc 3.2 on Mac OS 10.7 through MacPorts
> 2.0.3.  PETSc works fine by itself, but SLEPc fails on the initial
> EPSCreate call.  The error follows.
> This is presumably a MacPorts misconfiguration issue, but thought I'd
> check here first to see if anyone has seen this before in a similar
> situation.  Only static libraries exist, so as far as I know the
> suggested explanation doesn't apply.  The conf directory is at
> http://naml.us/~irving/random/petsc-conf.tar.gz if it helps.
Just in case, please run:
$ otool -L ./your_executable
Do you have any other PETSc/SLEPc build lying around?
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
