[petsc-users] memory increase in a transient calculation but no valgrind errors
Sat Dec 24 11:12:31 CST 2011
On Sat, Dec 24, 2011 at 9:36 AM, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> I am doing a transient calculation, allocating and deallocating
> several matrices and vectors both between nonlinear iterations as well
> as between time steps.
> I measure (with dstat) a constant linear memory increase as the
> calculation progresses. I have run my solver on a small example
> through valgrind, however, no leaks / unfreed memory have been
> reported. Are there any other possibilities to find out where the
> memory goes to?
> Many thanks for any hints.
Its always possible that dstat is showing memory fragmentation. If the
problems are the same size, you might benefit from pooling.
   Matt
> Dominik
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111224/64163266/attachment.htm>
