[petsc-users] Packages Similar to PETSc in C++?
Mohammad Mirzadeh mirzadeh at gmail.com
Sat Oct 30 15:46:00 CDT 2010
Thanks guys. I will definitely spend sometime and consider these packages.
The truth is I really like the structure of PETSc and I want to stick with
it as much as possible.
If I can use any of these packages to replace for my data structure in the
grid generation phase, I'll probably be able to port most of my code from
serial into parallel. Hopefully it will be good enough (in the long term)
that I can eventually publish it and be of help to the community.
Mohammad
On Sat, Oct 30, 2010 at 10:06 AM, Pearl Flath <pflath at ices.utexas.edu>wrote:
> Mohammad,
> You could also look into p4est, which also interfaces with the deal II
> library (and deal II has wrappers for calling either PETSc or Trilinos).
> "The p4est software library enables the dynamic management of a collection
> of adaptive octrees, conveniently called a forest of octrees. p4est  is
> designed to work in parallel and scale to hundreds of thousands of processor
> cores." http://p4est.org/
> Best,
> Pearl Flath
> On Sat, Oct 30, 2010 at 10:32 AM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa>wrote:
>> Mohammad,
>> I am sure some of the other users and developers here will have
>> different opinions on the correct way to approach this.
>> It sounds like you may benefit even more from investigating several of
>> the packages that manage meshes and grids on parallel architectures.
>> There are some very general toolkits for managing adaptive grids and
>> meshes out there, one could start with Sieve or deal.ii.  If one of
>> these packages is suitable for you, I strongly suggest you consider
>> reusing as much of their frameworks as possible to avoid "rewriting
>> the wheel" so to speak.
>> Cheers,
>> Aron
>> On Sat, Oct 30, 2010 at 9:07 AM, Mohammad Mirzadeh <mirzadeh at gmail.com>
>> wrote:
>> > Aron,
>> > Thanks for the quick reply. It's really great that PETSc has such an
>> awesome
>> > community.
>> > Anyway, I am working on adaptive Cartesian grids for which I use
>> > Octree/Quadtree data structures. Naturally, then, I have components like
>> > cells, nodes, neighbors, child/parent, etc and my whole domain is
>> consisted
>> > of arrays of these types. That is, if I happen to have 100 cells and 200
>> > nodes, for example, I create an array for the whole domain by calling,
>> > Array<Cell> *CellArray = new Array<Cell> [100];
>> > Array<Node> *NodeArray = new Array<Node> [200];
>> > Now the problem is I want to be able to distribute this in parallel and
>> have
>> > an array of cells or nodes. I understand that one of doing this is to
>> change
>> > my data structure such that is consistent with PETSc only accepting
>> double.
>> > I was hoping I could prevent that by using a package that allow for
>> > templates. That being said, I am not an expert on PETSc by any measure!
>> As a
>> > result I highly appreciate any ideas and comments if you think this is
>> > possible to do with PETSc.
>> > All the best,
>> > Mohammad
>> > On Fri, Oct 29, 2010 at 10:44 PM, Aron Ahmadia <
>> > wrote:
>> >> Dear Mohammad,
>> >> As a user of PETSc for the last 8 years, since my days as an
>> >> undergraduate, and now as a professional staff scientist at a
>> >> supercomputing center, I can say with some confidence that there are
>> >> no codes like PETSc in C++ or any other language in terms of quality
>> >> of implementation, documentation, and support.  Can you tell us a
>> >> little more about your current implementation?  It is true that PETSc
>> >> does not support multiple types in the same build, but you do get your
>> >> choice of floating-point values and real or complex types.  Also,
>> >> PETSc has several C++ components within it, and one of the supported
>> >> ways of building it is in 'C++' mode, see -c-language in the configure
>> >> options.
>> >> If you insist on departing us (we'll miss you), I suggest you look at
>> >> Sandia's Trilinos package: http://trilinos.sandia.gov/
>> >> Good Luck,
>> >> Aron
>> >> On Sat, Oct 30, 2010 at 7:54 AM, Mohammad Mirzadeh
>> >> <m.mirzadeh at engineering.ucsb.edu> wrote:
>> >> > Dear all,
>> >> > I was wondering if anyone can refer me to a package similar to PETSc
>> but
>> >> > that is written in c++? Right now I have a large code written in c++
>> for
>> >> > doing CFD simulations that I need to transform from serial to
>> parallel.
>> >> > Initially I was thinking of PETSc and tried using it but found that
>> >> > PETSc is
>> >> > written in C and thus does not allow to have arrays (in parallel) of
>> >> > arbitrary type. I have a big data structure and it is much easier for
>> me
>> >> > to
>> >> > retain the current structure and form of the code. As a result I was
>> >> > wondering if you guys know of any similar package in C++ ?(in the
>> sense
>> >> > that
>> >> > it can provide with efficient linear solvers in parallel while hiding
>> >> > most
>> >> > of MPI from the user)
>> >> > I could think of HYPRE but then again I am not sure it is written in
>> >> > C++.
>> >> > Thanks,
>> >> > Mohammad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101030/ea5f6073/attachment.htm>
