[petsc-users] positive definite MPISBAIJ-Matrix gets singular in the case of more than one MPI-process
Andreas Hauffe andreas.hauffe at tu-dresden.de
Tue Jun 8 02:33:47 CDT 2010
Dear all,
I want to solve a linear System with a symmetric positive definite matrix. I
use the external package MUMPS as solver with the following commands
 call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
 call KSPSetOperators(ksp,mat,mat,DIFFERENT_NONZERO_PATTERN,ierr)
 call KSPSetType(ksp,KSPPREONLY,ierr)
 call KSPGetPC(ksp,prec,ierr)
 call PCSetType(prec,PCCHOLESKY,ierr)
 call PCFactorSetMatSolverPackage(prec,MAT_SOLVER_MUMPS,ierr)
 call KSPSetFromOptions(ksp,ierr)
 call KSPSolve(ksp,vec1,vec2,ierr)
and give the option "-mat_mumps_sym 1" (symmetric positive definite).
If I run the program with one MPI-process everything works fine. For a low
number of unknows it also works for more MPI-processes. If I increase the
number of unknows (>50000) and use more then one MPI-process on one or more
host, I get a MUMPS error that the matrix is singular. With one MPI-process
everything is still fine. The critical value for the number of unknows
depends also on the use of the debug-version or non-debug-version of PETSc.
If I do not use the option "-mat_mumps_sym 1" everything also works.
Right now the finite element assembling process (MatSetValue) is only done
with rank 0. So the hole matrix gets all its values only from rank 0.
Could someone explain this behaviour? Where is my error?
Btw, I am currently using PETSc 3.0 since I work with SLEPc as well.
Thank you very much,
Andreas Hauffe
Technische Universität Dresden
Institut für Luft- und Raumfahrttechnik / Institute of Aerospace Engineering
Lehrstuhl für Luftfahrzeugtechnik / Chair of Aircraft Engineering
D-01062 Dresden
Germany
phone   : (++49)351 463 38496
fax     : (++49)351 463 37263
mail    : andreas.hauffe at tu-dresden.de
Website : http://tu-dresden.de/mw/ilr/lft
