[petsc-users] T^t*K*T for SEQSBAIJ matrix type
Jose E. Roman jroman at dsic.upv.es
Mon Jun 7 08:55:03 CDT 2010
On 07/06/2010, Martin Rädel wrote:
> Dear All,
> I try to multiply matrices in the following way:
> K_=T^t*K*T
> where K is symmetric and positive definite and has the type SEQSBAIJ and T is
> nonsymmetric and has the type SEQAIJ.
> I searched the manual for possibilities to compute this task but I just found
> MatMatMultTranspose which is only applicable for matrices of type SEQAIJ and
> MatPtAP which only works for AIJ-type matrices.
> Is there a way to calculate T^t*K*T for the used matrix types (K=SEQSBAIJ) ?
> Thank you very much,
> Martin
> Btw, I am currently using PETSc 3.0 since I work with SLEPc as well.
> Martin Rädel
I would suggest giving up the SEQSBAIJ and using MatPtAP.
Depending on the situation, an alternative could be to use a shell matrix instead of forming T^t*K*T explicitly. If for instance this matrix is the eigenproblem matrix in EPS, you can consider using SLEPc's ex3.c as a basis and define the MatMult operation to perform the sequence MatMult(T), MatMult(K), MatMultTranspose(T).
Best,
Jose E. Roman
