[petsc-users] Termination criteria for solving linear system
Markus Bürg buerg at kit.edu
Tue Feb 2 06:30:25 CST 2010
Hello Thomas,
the precision of the solver does not correspond to the precision of the
solution for your problem. If you do not want such a small residual in
your problem, you have to reduce the number of degrees of freedom.
Best Regards,
Markus
Am 02.02.10 13:05, schrieb Thomas Witkowski:
> In my computations I use "bicg" preconditioned by "bjacobi" with an
> absolute tolerance of 1^e-8 as termination criteria. After PETSc has
> computed the solution, the code computes the residual. It is usually
> in the magnitude of 1^-13. I'm not really sure what happens here. Is
> it, because PETSc checks the preconditioned residual? If so, is there
> a way to tune the termination criteria to the true residual? I would
> like to save some computational time, since I do not need to solve the
> system with this high precision.
> Regards,
> Thomas
