SNES and internar variables
Lukasz Kaczmarczyk likask at civil.gla.ac.uk
Wed Sep 30 10:15:43 CDT 2009
Hello,
I like to use  SNES to solve nonlinear system of equations. For my
problem, I have to update some internal variables for computed newtons
increments of primary unknowns, before I update residual (right hand
side) and Jacobian. I found function SNESSetUpdate which is called at
the beginning o every iteration. But I am not sure enough if that
function is proper for updating internal variables. Can You advise me
if it is right to use internal variables, f.e. increments of plastic
strain at gauss points.
Such problems exist  in solid mechanics when increment of plastic
strain and plastic multiplayer have to be computed. Another example is
for hybrid/mixed FE discretisation having some variables approximated
with C(-1) continuity. Unknowns associated to C(-1) continuos
approximations  can be statically condensed , see attached file. As a
results at each iteration step increments for statically condense
variables have to be updated.
Lukasz Kaczmarczyk
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090930/4c015d1c/attachment-0001.pdf>
