ell1 norm convergence test
Ryan Yan vyan2000 at gmail.com
Mon Sep 21 13:59:07 CDT 2009
Hi Matt,
Thanks for the pointer.
Yan
On Mon, Sep 21, 2009 at 2:40 PM, Matthew Knepley <knepley at gmail.com> wrote:
> You can use KSPBuildResidual().
>   Matt
> On Mon, Sep 21, 2009 at 12:44 PM, Ryan Yan <vyan2000 at gmail.com> wrote:
>> Hi All,
>> The following question is only for test and comparison reason.
>> Is there a command line option to set up using 1-Norm(sum of absolute
>> value of residuals)  as convergence monitor and test.
>> Alternatively, if I can get the residual "r" out at the end of each
>> iteration, then it is going to be much simpler, since I can just call
>> VecNorm(r, NORM_1, &r_ell1) and pass the r_ell1 into the convergence monitor
>> and test. Can anyone inform me if PETSc has an interface for the resuidual
>> r?
>> Or one has to call the convergence test:
>> MyKSPConverged(ksp,n,rnorm,flag,dummy);
>> and following the steps:
>> 1. fetch the exact solution:
>> KSPBuildSolution(ksp,PETSC_NULL_OBJECT,x,ierr)
>> 2. calculate the residual:
>> pass the Right Hand side and the Matrix in to calculate the 1-Norm. But
>> this step is *not* obvious, since the matrix and rhs is already distributed
>> over each processes.
>> 3. set up the convergence test based on the 1_Norm residual.
>> Thank you very much,
>> Yan
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090921/8049dfb5/attachment.htm>
