MPIBAIJ and sor
Fri Oct 30 17:14:40 CDT 2009
    I have added the support for SOR with MPIBAIJ matrices
(MatSOR_MPIBAIJ()) to petsc-dev. (Note as in the discussion this is
actually block Jacobi with SOR on each process).
    I have changed the name of MatRelax() to MatSOR() in petsc-dev so
that a consistent name is used, instead of sometimes using relax.
    I have also merged the MatPBRelax() into MatRelax() in petsc-dev
(now MatSOR()) to simplify and clarify the code.
    Barry
On Oct 27, 2009, at 4:04 PM, Barry Smith wrote:
>   I completely forgot about the MatPBRelax_ routines.
>   MatRelax() which is used by PCSOR automatically tries
> MatRelax_xxx() for the matrix and then MatPBRelax_xxx()  if the
> MatRelax_xxx() does not exist.
>   MatRelax_MPIAIJ() (and MatRelax_MPISBAIJ()) handles the block
> Jacobi and relax on each block automatically and allows for any
> number of local smoothing before updating the ghost points.
>   If you need MatPBRelax_SeqBAIJ_N() for N > 7 that is very easily
> added by taking the 7 case and extending it.
>   Barry
>  This discussion brings up a few issues
> 1) having the MatRelax() and MatPBRelax() both is a bit confusing.
> As Jed points out it is possible to write a MatRelax() for BAIJ, but
> that is almost always silly since essentially the same number
>     of floating point operations gives you the better point block
> relaxation. I originally thought we might support all point-block
> and point relaxation for all matrix types and hence have both the
>     MatRelax() and MatPBRelax(). Perhaps that was unneededly general
> and we should merge them. Then I wouldn't have searched for
> MatRelax_SeqBAIJ and given you the wrong answer initially.
> 2) Using SOR as the name of the preconditioner but relax as the name
> of the matrix operation is questionable. Better to use the same name
> everywhere?
> 3) One could very easily modify the MatRelax_MPIAIJ() to get a
> MatRelax_MPIBAIJ() and we should do that (and test it). But as Jed
> points out it is redundant (as is MatRelax_MPIAIJ()).
> On Oct 27, 2009, at 3:39 PM, Jed Brown wrote:
>> Stephan Kramer wrote:
>>> I'm slightly confused by the fact that if I use my BAIJ matrix in
>>> parallel and select the sor preconditioner. it complains about
>>> mat->ops->relax and mat->ops->pbrelax not being defined.
>> There is no parallel SOR, it would make the algorithm nearly serial.
>> Use -sub_pc_type sor with -ksp_type asm or bjacobi.
>>> Also I can't find a MatRelax_MPIBAIJ in
>>> src/mat/impls/baij/mpi/mpibaij.c as I would have expected. Is
>>> there no
>>> sor type relaxation for parallel block matrices at all?
>> Since the small dense blocks are available at once, it would be
>> silly to
>> relax each component separately (your CPU spends most of its time
>> waiting on memory).  Instead, BAIJ relaxes all components
>> simultaneously
>> by solving with these small blocks.  This is "point-block"
>> relaxation,
>> look for MatPBRelax_SeqBAIJ_N for N in 1..7.
>> Jed
