MPIBAIJ and sor
Jed Brown jed at 59A2.org
Tue Oct 27 15:39:42 CDT 2009
Stephan Kramer wrote:
> I'm slightly confused by the fact that if I use my BAIJ matrix in
> parallel and select the sor preconditioner. it complains about
> mat->ops->relax and mat->ops->pbrelax not being defined.
There is no parallel SOR, it would make the algorithm nearly serial.
Use -sub_pc_type sor with -ksp_type asm or bjacobi.
> Also I can't find a MatRelax_MPIBAIJ in
> src/mat/impls/baij/mpi/mpibaij.c as I would have expected. Is there no
> sor type relaxation for parallel block matrices at all?
Since the small dense blocks are available at once, it would be silly to
relax each component separately (your CPU spends most of its time
waiting on memory).  Instead, BAIJ relaxes all components simultaneously
by solving with these small blocks.  This is "point-block" relaxation,
look for MatPBRelax_SeqBAIJ_N for N in 1..7.
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091027/5db91f44/attachment.pgp>
