KSP different results with the default and direct LU
    Umut Tabak
    u.tabak at tudelft.nl
    Thu Oct 22 06:08:19 CDT 2009
Dear all,
I am trying get myself more acquainted with PETSc.
I am trying to solve a linear equation system which is conditioned
badly. If I use the approach as given in ex1.c of the KSP section(by
default, I read from the manual that it uses restarted GMRES ,
preconditioned with JACOBI in ex1.c which I am not very aware of these
numerical procedures that in deep). I get some wrong results for the
solution.
I checked my results with Matlab, If I use the command line options as
suggested on page 68 of the manual, to solve it directly, -ksp_type
preonly -pc_type lu, I can both get the right solution and it is faster
than the iterative solution which is used by default. So as far as I can
follow from the mailing list, iterative methods and preconditioners are
problem dependent, so my question would be, should I find the right
approach/solver combination by some trial and error by using different
combinations that are outlined in the manual?(This can also be dependent
on the problem types that I would like to solve as well I suppose, for
the moment, quite badly conditioned.)
Any pointers are appreciated.
Best regards,
Umut
