[petsc-maint #36400] Re: C++ error! MPI_Finalize() could not be located!
Dominik Szczerba dominik at itis.ethz.ch
Wed Oct 21 16:09:55 CDT 2009
Thanks, the error is gone. That really saved my day!
But you have to agree the connection between --with-cxx=icpc and
"MPI_Finalize() could not be located!" is not trivially deduced.
with regards,
Dominik
Satish Balay wrote:
> Since you are using hypre - also use the additional option -with-cxx=icpc
> [by default its picking up g++ - which is causing this incompatibility with icc etc..]
> Satish
> On Wed, 21 Oct 2009, Dominik Szczerba wrote:
>> configure.log is attached. Looking forward your feedback.
>> 	Dominik
>> Matthew Knepley wrote:
>>> Send configure.log to petsc-maint at mcs.anl.gov
>>> <mailto:petsc-maint at mcs.anl.gov>
>>>   Matt
>>> On Wed, Oct 21, 2009 at 6:23 AM, Dominik Szczerba <dominik at itis.ethz.ch
>>> <mailto:dominik at itis.ethz.ch>> wrote:
>>>     I get the following error building petsc-3.0.0-p8 on 32 bit linux
>>>     (Ubuntu 9.04):
>>>                                                     Running make on
>>>     MPICH; this may take several minutes
>>>                                               TESTING: CxxMPICheck from
>>>     config.packages.MPI(config/BuildSystem/config/packages/MPI.py:599)
>>>             UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
>>>     for details):
>>>     Tail of configure.log:
>>>     for details):
>>>      File "./config/configure.py", line 217, in petsc_configure
>>>        framework.configure(out = sys.stdout)
>>>      File
>>>     "/home/domel/pack/petsc-3.0.0-p8/config/BuildSystem/config/framework.py",
>>>     line 902, in configure
>>>        child.configure()
>>>      File
>>>     "/home/domel/pack/petsc-3.0.0-p8/config/BuildSystem/config/package.py",
>>>     line 445, in configure
>>>        self.executeTest(self.configureLibrary)
>>>      File
>>>     "/home/domel/pack/petsc-3.0.0-p8/config/BuildSystem/config/base.py",
>>>     line 97, in executeTest
>>>        ret = apply(test, args,kargs)
>>>      File
>>>     "/home/domel/pack/petsc-3.0.0-p8/config/BuildSystem/config/packages/MPI.py",
>>>     line 695, in configureLibrary
>>>        self.executeTest(self.CxxMPICheck)
>>>      File
>>>      File
>>>     line 613, in CxxMPICheck
>>>        raise RuntimeError('C++ error! MPI_Finalize() could not be located!')
>>>     The configure line:
>>>     ./config/configure.py --with-cc=icc --with-fc=ifort
>>>     --download-f-blas-lapack=1 --download-mpich=1 --download-hypre=1
>>>     --with-x=0
>>>     with the Intel compiler version 11.0.083 (with -long_double
>>>     and -no-multibyte-chars in icc.cfg).
>>>     The same configuration (OS, compilers, versions) but on 64 bit
>>>     system compiles fine. Any ideas? Google is silent.
>>>     with regards,
>>>     Dominik
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>> -- Norbert Wiener
