GMRES performance
jarunan at ascomp.ch jarunan at ascomp.ch
Thu Oct 22 03:37:21 CDT 2009
Hello,
I followed the suggestion in PETSc previous threads by adding options
-pc_type asm -sub_pc_type lu
Now the solver is really fast!!!!!
Thanks you
Jarunan
Quoting Barry Smith <bsmith at mcs.anl.gov>:
> On Oct 20, 2009, at 9:52 AM, jarunan at ascomp.ch wrote:
>> Hello,
>> I would like to know some information about GMRES performance in
>> PETSc if you have any experience.
>> I am running a parallel test case(9300 cells) comparing cpu time
>> using by solvers in Petsc. While BICGSTAB was doing 0.9 sec, GMRES
>> 15 sec with the same preconditioner(Additive Schwarz). I did not
>> expect that GMRES would be that much slower. Everything is default.
>    You need much more information than runtimes of the two cases to
> understand why one is faster than the other.
>> Please share your experiences, how the performance of solvers are
>> in your test cases. Which option I should set to improve GMRES
>> performance? Is there the best combination of Preconditioner and
>> solver?
>    Run both (with debugging turned off, hence optimized) using the
> option -log_summary and look at where each is code is spending its
> time. You can also see how many iterations (MatMult) each solver is
> requiring. Feel free to send the -log_summary output to
> petsc-maint at mcs.anl.gov if you do not understand it.
>    Barry
>> Thank you very much
>> Jarunan
>> Jarunan Panyasantisuk
>> Development Engineer
>> ASCOMP GmbH, Technoparkstr. 1
>> CH-8005 Zurich, Switzerland
>> Phone : +41 44 445 4072
>> Fax   : +41 44 445 4075
>> E-mail: jarunan at ascomp.ch
>> www.ascomp.ch
www.ascomp.ch
