a problem with error of "An error occurred in MPI_Comm_rank after MPI was finalized"
Yin Feng yfeng1 at tigers.lsu.edu
Sun Oct 11 23:01:37 CDT 2009
I move PetscInitialize and PetscFinalize out of loop and it works now.
Thank you, Barry!
While, I found it runs very slow, do you know the reason of it?
On Sun, Oct 11, 2009 at 10:06 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  MPI does NOT allow calling MPI_Init() twice. (By default PetscInitialize()
> calls MPI_Init().)
>  You need to take the PetscInitialize() out of the subroutine and instead
> call it once at the beginning of your program.
>   Barry
> On Oct 11, 2009, at 9:59 PM, Yin Feng wrote:
>  The completed code is:
>> void PETSc(double mat[],double vec[],double sol[],long N,double tol) {
>>        Vec            x,b;
>>        Mat            A;
>>        KSP            ksp;
>>        PC             pc;
>>        PetscInt       i,j,col[N];
>>        PetscScalar    value[N];
>>        PetscScalar    val;
>>        PetscInitialize(PETSC_NULL,PETSC_NULL,PETSC_NULL,PETSC_NULL);
>>        VecCreate(PETSC_COMM_WORLD,&x);
>>        VecSetSizes(x,PETSC_DECIDE,N);
>>        VecSetFromOptions(x);
>>        VecDuplicate(x,&b);
>>        MatCreate(PETSC_COMM_WORLD,&A);
>>        MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,N,N);
>>        MatSetFromOptions(A);
>>        for (i=0; i<N; i++) {
>>                for (j=0;j<N;j++) {
>>                        value[j]=mat[i*N+j];
>>                        col[j]=j;
>>                MatSetValues(A,1,&i,N,col,value,INSERT_VALUES);
>>        MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
>>        MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
>>                val=vec[i];
>>                VecSetValues(b,1,&i,&val,INSERT_VALUES);
>>                val=sol[i];
>>                VecSetValues(x,1,&i,&val,INSERT_VALUES);
>>        VecAssemblyBegin(b);
>>        VecAssemblyEnd(b);
>>        KSPCreate(PETSC_COMM_WORLD,&ksp);
>>        KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);
>>        KSPGetPC(ksp,&pc);
>>        KSPSetType(ksp, KSPGMRES);
>>        PCSetType(pc,  PCBJACOBI);
>>  KSPSetTolerances(ksp,tol,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);
>>  KSPSetFromOptions(ksp);
>>  KSPSolve(ksp,b,x);
>>  for (i=0;i<N;i++) {
>>      VecGetValues(x,1,&i,&sol[i]);
>>  VecDestroy(x);
>>  VecDestroy(b);
>>  MatDestroy(A);
>>  KSPDestroy(ksp);
>>  PetscFinalize();
>> Once this function is call in a loop, it reports error.
>> On Sun, Oct 11, 2009 at 9:38 PM, Yin Feng <yfeng1 at tigers.lsu.edu> wrote:
>> I put PETSc solver in one function and use another function to call that.
>> This problem only appears when I put the function with PETSc solver in a
>> loop,
>> it works well at first step, and reports error "An error occurred in
>> at second time. The program is designed to support only one processor
>> like:
>> Vec            x,b;
>> Mat            A;
>> KSP            ksp;
>> PC             pc;
>> PetscScalar    val;
>> VecDuplicate(x,&b);
>> KSPGetPC(ksp,&pc);
>>        KSPSolve(ksp,b,x);
>>        VecDestroy(x);
>>        VecDestroy(b);
>>        MatDestroy(A);
>>        KSPDestroy(ksp);
>>        PetscFinalize();
>> Any one has ideal about this?
>> The detailed error description is:
>> *** after MPI was finalized
>> *** MPI_ERRORS_ARE_FATAL (goodbye)
>> Abort before MPI_INIT completed successfully; not able to guarantee that
>> all other processes were killed!
>> Thank you so much in advance!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091011/34e4a95e/attachment-0001.htm>
