a problem with error of "An error occurred in MPI_Comm_rank after MPI was finalized"
Sun Oct 11 22:06:49 CDT 2009
   MPI does NOT allow calling MPI_Init() twice. (By default
PetscInitialize() calls MPI_Init().)
   You need to take the PetscInitialize() out of the subroutine and
instead call it once at the beginning of your program.
    Barry
On Oct 11, 2009, at 9:59 PM, Yin Feng wrote:
> The completed code is:
> void PETSc(double mat[],double vec[],double sol[],long N,double tol) {
> 	Vec            x,b;
> 	Mat            A;
> 	KSP            ksp;
> 	PC             pc;
> 	PetscInt       i,j,col[N];
> 	PetscScalar    value[N];
> 	PetscScalar    val;
> 	PetscInitialize(PETSC_NULL,PETSC_NULL,PETSC_NULL,PETSC_NULL);
> 	VecCreate(PETSC_COMM_WORLD,&x);
> 	VecSetSizes(x,PETSC_DECIDE,N);
> 	VecSetFromOptions(x);
> 	VecDuplicate(x,&b);
> 	MatCreate(PETSC_COMM_WORLD,&A);
> 	MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,N,N);
> 	MatSetFromOptions(A);
> 	for (i=0; i<N; i++) {
> 		for (j=0;j<N;j++) {
> 			value[j]=mat[i*N+j];
> 			col[j]=j;
> 		MatSetValues(A,1,&i,N,col,value,INSERT_VALUES);
> 	MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
> 	MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
> 		val=vec[i];
> 		VecSetValues(b,1,&i,&val,INSERT_VALUES);
> 		val=sol[i];
> 		VecSetValues(x,1,&i,&val,INSERT_VALUES);
> 	VecAssemblyBegin(b);
> 	VecAssemblyEnd(b);
> 	KSPCreate(PETSC_COMM_WORLD,&ksp);
> 	KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);
> 	KSPGetPC(ksp,&pc);
>         KSPSetType(ksp, KSPGMRES);
>         PCSetType(pc,  PCBJACOBI);
>  KSPSetTolerances(ksp,tol,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);
>   KSPSetFromOptions(ksp);
>   KSPSolve(ksp,b,x);
>   for (i=0;i<N;i++) {
>       VecGetValues(x,1,&i,&sol[i]);
>   VecDestroy(x);
>   VecDestroy(b);
>   MatDestroy(A);
>   KSPDestroy(ksp);
>   PetscFinalize();
> Once this function is call in a loop, it reports error.
> On Sun, Oct 11, 2009 at 9:38 PM, Yin Feng <yfeng1 at tigers.lsu.edu>
> wrote:
> I put PETSc solver in one function and use another function to call
> that.
> This problem only appears when I put the function with PETSc solver
> in a loop,
> it works well at first step, and reports error "An error occurred in
> at second time. The program is designed to support only one
> processor like:
> Vec            x,b;
> Mat            A;
> KSP            ksp;
> PC             pc;
> PetscScalar    val;
> VecDuplicate(x,&b);
> KSPGetPC(ksp,&pc);
>         KSPSolve(ksp,b,x);
>         VecDestroy(x);
>         VecDestroy(b);
>         MatDestroy(A);
>         KSPDestroy(ksp);
>         PetscFinalize();
> Any one has ideal about this?
> The detailed error description is:
> *** after MPI was finalized
> *** MPI_ERRORS_ARE_FATAL (goodbye)
> Abort before MPI_INIT completed successfully; not able to guarantee
> that all other processes were killed!
> Thank you so much in advance!
