Multiple communicators
irfan.khan at gatech.edu irfan.khan at gatech.edu
Tue Nov 24 19:56:12 CST 2009
I don't explicitly use the communicator PETSC_COMM_WORLD. Instead I used MPI_COMM_WORLD, which according to the manual should be the same.
However, I create two new communicator from MPI_COMM_WORLD using MPI_Comm_split(). LBM_Comm and FEA_Comm. Only the ranks in FEA_Comm make use of KSP solver and PARMETIS. When creating objects for mesh partitioning (MatPartitioningCreate()) and solver (KSPCreate()), I use the new communicator FEA_Comm. Would this have any effect on the command line options?
Regards
Irfan
I am not sure what you are doing, but something is wrong in this code. Using different communicators does not
have much to do with options. Any object (like a KSP) can be created using a subcomm of WORLD. Are you
setting PETSC_COMM_WORLD to something different? That is not necessary here.
Matt
Thank you
Irfan
----- Original Message -----
To: "PETSc users list" < petsc-users at mcs.anl.gov >
Sent: Tuesday, November 24, 2009 8:03:00 PM GMT -05:00 US/Canada Eastern
Subject: Re: Multiple communicators
On Tue, Nov 24, 2009 at 6:59 PM, < irfan.khan at gatech.edu > wrote:
Hello
Does the procedure for providing command line options and to obtain profiling data through -log_summary change if there are multiple MPI communicators in a petsc code?
There is always WORLD, so it should be fine unless I misunderstand your question.
Matt
If so, can somebody point me to information, references on how to provide command line options if there are multiple communicators?
Thank you
Irfan
PhD Candidate
G.W. Woodruff School of Mechanical Engineering
Georgia Institute of Technology
Atlanta, GA (30332)
-- Norbert Wiener
PhD Candidate
Atlanta, GA (30332)
-- Norbert Wiener
PhD Candidate
Atlanta, GA (30332)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091124/d6cdbbed/attachment.htm>
