Multiple communicators
irfan.khan at gatech.edu irfan.khan at gatech.edu
Tue Nov 24 19:13:36 CST 2009
I use seperete communicators for fluid and solid ranks in a fluid-structure interaction code. I use PETSc tools (KSP) to solve for the solid phase (FEA) which is carried out under a different communicator (FEA_Comm).
Unless I am doing something wrong, I have found that the command line options: -ksp_type; -mat_partitioning_type, don't work if there are 2 communicators. But for single communicator they work. Please see the attached files containing output of -log_summary for 2 different codes (scroll down to the end). One with single communicator and the other with two communicators. Both the output have been generated with the same PETSc compilation.
Futher -log_summary results are not able to detect all the events that have been registered if they are not in the WORLD communicator.
Thank you
Irfan
----- Original Message -----
To: "PETSc users list" <petsc-users at mcs.anl.gov>
Sent: Tuesday, November 24, 2009 8:03:00 PM GMT -05:00 US/Canada Eastern
Subject: Re: Multiple communicators
On Tue, Nov 24, 2009 at 6:59 PM, < irfan.khan at gatech.edu > wrote:
Hello
Does the procedure for providing command line options and to obtain profiling data through -log_summary change if there are multiple MPI communicators in a petsc code?
There is always WORLD, so it should be fine unless I misunderstand your question.
Matt
If so, can somebody point me to information, references on how to provide command line options if there are multiple communicators?
Thank you
Irfan
PhD Candidate
G.W. Woodruff School of Mechanical Engineering
Georgia Institute of Technology
Atlanta, GA (30332)
-- Norbert Wiener
PhD Candidate
Atlanta, GA (30332)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091124/225e71c7/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091124/225e71c7/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091124/225e71c7/attachment-0003.obj>
