petsc-users Digest, Vol 11, Issue 17
Wed Nov 18 14:53:52 CST 2009
    This only gives the final residual norm as computed by the Krylov
method; so depending on your options it may be a preconditioned
residual norm.
    If you want the true residual norm then you should compute it via
the formula || b - A*x|| in your Fortran code after the KSPSolve()
    Barry
On Nov 18, 2009, at 2:21 PM, Matthew Knepley wrote:
> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/KSP/KSPGetResidualNorm.html
>   Matt
> On Wed, Nov 18, 2009 at 2:19 PM, <hxie at umn.edu> wrote:
> Hi,
> I want to output the true residual norm after calling KSPSolve in a
> fortran program. I know there is a command option '-
> ksp_final_residual', but I cannot do this using the PBS job
> submission. What is the related fortran subroutine for this? Thanks
> for your help.
> Bests,
> Hui
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
