include file fortran
Tahar Amari amari at cpht.polytechnique.fr
Fri May 15 19:03:27 CDT 2009
Hello,
Thanks a lot, I will let you know.
Tahar
Le 16 mai 09 à 01:54, Satish Balay a écrit :
> On Sat, 16 May 2009, Tahar Amari wrote:
>> I do not have any "reply".
>> Following your advice I will rebuild PETSC with
>> only C and fortran (even when I do C++ I do not intend to use the C++
>> wrappers, but the C ones) at the level
>> of linear algebra.
> If you have PETSc calls from C++ code - its best to build c++/fortran
> version as indicated before. [but using c-petsc from c++ code is also
> possible - it just means the makefile will get more complex]
>> Would you aggree with this ? I followed the advice of not loading
>> --download-f-blas-lapack
>> since one of your colleague explained that it should look for the
>> APPLE one ?
>> I changed with-cc=gcc by with-cc=cc, is is OK ?
> cc is same as gcc
>> configure -with-cc=cc --download-mpich=1 --download-parmetis=1 --
>> with-shared=0
>> --with-fc=ifort --with-dynamic=0
> If you still have problems compiling your fortran code with a PETSc
> makefile - let us know..
> Satish
