solving a particular linear equation system
Christian May cmay at phys.ethz.ch
Fri May 15 16:23:19 CDT 2009
On Fri, 15 May 2009, Matthew Knepley wrote:
> 3) Run with -pc_type lu -ksp_type preonly first to test.
Thanks for your hints.
This works fine: Linear solve converged due to CONVERGED_ITS iterations 1
On Fri, 15 May 2009, Barry Smith wrote:
>  Could you please save this matrix and right hand side using
> -ksp_view_binary (just run solver like you usually do but use this command
> line option also) then post the file binaryoutput that is generated. This way
> people can trivially load the matrix and right hand side with MatLoad() and
> not monkey with parsing ASCII files.
Sure, I wasn't aware of this option. The file is now available at
http://www.mayarea.de/download/binaryoutput
Thanks a lot
Christian
