include file fortran
Tahar Amari amari at cpht.polytechnique.fr
Fri May 15 16:04:00 CDT 2009
Excuse me I did not know there are petsc makefiles ?
This is certainly better.
Do you suggest me to look in the example or tutorials folders ?
Tahar
Le 15 mai 09 à 22:34, Satish Balay a écrit :
> Ah. - the problem is your makfile. Its best to use PETSc makefiles.
>>>> ifort -assume byterecl  -g  -I/usr/local/petsc/
> It should be:  -I/usr/local/petsc/include
> Satish
> On Fri, 15 May 2009, Tahar Amari wrote:
>> Thank you very much ,
>> excuse me, I might not have well understood,
>> ctually there are  petsc.h , petscvec.h .... files
>> in
>> petsc/include/finclude/
>> Le 15 mai 09 à 22:21, Satish Balay a écrit :
>>> You'll have to modify to:
>>> #include "finclude/petsc.h"
>>> #include "finclude/petscvec.h"
>>> #include "finclude/petscmat.h"
>>> #include "finclude/petscao.h"
>>> Satish
>>>> Hello
>>>> Here is what I have from a FORTRAN code "toto.fpp" which was
>>>> compiled with
>>>> petsc2..xxxx
>>>> c
>>>> #include "include/finclude/petsc.h"
>>>> #include "include/finclude/petscvec.h"
>>>> #include "include/finclude/petscmat.h"
>>>> #include "include/finclude/petscao.h"
>>>> I compiled it with
>>>> -I/usr/local/petsc//macx/include -I/usr/X11R6/include/X11
>>>> -DPETSC_HAVE_PARMETIS -DPETSC_USE_DEBUG -DPETSC_USE_LOG -
>>>> DPETSC_USE_BOPT_g
>>>> -DPETSC_USE_STACK -DPETSC_AVOID_MPIF_H -c toto.fpp
>>>> I have the following kind of errors
>>>> petsc.h(6): #error: can't find include file: petscversion.h
>>>> petsc.h(7): #error: can't find include file: finclude/petscdef.h
>>>> petscvec.h(5): #error: can't find include file: finclude/
>>>> petscvecdef.h
>>>> I looked at my petsc tree and II  have the  "include/finclude/"
>>>> directory.
>>>> I have a petsc.h file inside
>>>> which does
>>>> #include "petscconf.h"
>>>> #include "petscversion.h"
>>>> #include "finclude/petscdef.h"
>>>> Does anyone knows  why it does not find those paths or what is
>>>> wrong with
>>>> those paths ?
>>>> Tahar
