include file fortran
Fri May 15 15:34:54 CDT 2009
Ah. - the problem is your makfile. Its best to use PETSc makefiles.
> > > ifort -assume byterecl  -g  -I/usr/local/petsc/
It should be:  -I/usr/local/petsc/include
Satish
On Fri, 15 May 2009, Tahar Amari wrote:
> Thank you very much ,
> excuse me, I might not have well understood,
> ctually there are  petsc.h , petscvec.h .... files
> in
> petsc/include/finclude/
> Le 15 mai 09 à 22:21, Satish Balay a écrit :
> > You'll have to modify to:
> > #include "finclude/petsc.h"
> > #include "finclude/petscvec.h"
> > #include "finclude/petscmat.h"
> > #include "finclude/petscao.h"
> > Satish
> > > Hello
> > > Here is what I have from a FORTRAN code "toto.fpp" which was compiled with
> > > petsc2..xxxx
> > > c-----------------------------------------------------------------------
> > > #include "include/finclude/petsc.h"
> > > #include "include/finclude/petscvec.h"
> > > #include "include/finclude/petscmat.h"
> > > #include "include/finclude/petscao.h"
> > > I compiled it with
> > > -I/usr/local/petsc//macx/include -I/usr/X11R6/include/X11
> > > -DPETSC_HAVE_PARMETIS -DPETSC_USE_DEBUG -DPETSC_USE_LOG -DPETSC_USE_BOPT_g
> > > -DPETSC_USE_STACK -DPETSC_AVOID_MPIF_H -c toto.fpp
> > > I have the following kind of errors
> > > petsc.h(6): #error: can't find include file: petscversion.h
> > > petsc.h(7): #error: can't find include file: finclude/petscdef.h
> > > petscvec.h(5): #error: can't find include file: finclude/petscvecdef.h
> > > I looked at my petsc tree and II  have the  "include/finclude/" directory.
> > > I have a petsc.h file inside
> > > which does
> > > #include "petscconf.h"
> > > #include "petscversion.h"
> > > #include "finclude/petscdef.h"
> > > Does anyone knows  why it does not find those paths or what is wrong with
> > > those paths ?
> > > Tahar
