petsc on mac os x
Håkan Jakobsson hakan.jakobsson at math.umu.se
Fri May 15 11:07:16 CDT 2009
Hi, I can confirm petsc 3.0.0 on 10.5 with openmpi 1.3.2. Configuration
options were
--with-fc=0 with-mpi-dir=/usr/local/openmpi
Håkan
On Fri, May 15, 2009 at 4:45 PM, Tahar Amari <amari at cpht.polytechnique.fr>wrote:
> Hello Sean
> Thank you very much for this help.
> I cannot see in the configure  anything about MPI. Do you mean
> that you do need to link with MPI , and this will be only at the link of
> your application ?
> Many thanks again
> Tahar
> Le 15 mai 09 à 16:39, Sean Dettrick a écrit :
> I configured petsc-2.3.3-p10 on OSX 10.5 using an openmpi built with gcc
> 4.0.1 gcc compiler.  It works.  The petsc config flags were:--with-matlab=0
> --with-shared=0 --with-dynamic=0 --with-fortran=0I believe that
> --with-dynamic=0 is important on OSX.
> Also if you happen to have intel MKL:
> --with-blas-lapack-dir=/Library/Frameworks/Intel_MKL.framework/Libraries/32
> I hope that helps.
> Sean
> On May 15, 2009, at 1:41 AM, Tahar Amari wrote:
> Hello ,
> I am a new petsc user. I am trying to built petsc on mac os 10 (10.4 and
> 10.5), but
> always have errors.
> Has anyone already built petsc for MAC OS X (any version of petsc or mac os
> x) .
> If yes I would be grateful to get the configure options and the minimum
> requirements.
> If it is not possible to built it  I would also appreciate to know it.
> Thank you very much
> Tahar
> T. Amari
> Centre de Physique Theorique
> Ecole Polytechnique
> 91128 Palaiseau Cedex France
> tel : 33 1 69 33 42 52
> fax: 33 1 69 33 30 08
> email: <mailto:amari at cpht.polytechnique.fr <amari at cpht.polytechnique.fr>>
> URL : http://www.cpht.polytechnique.fr/cpht/amari
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090515/a9054677/attachment.htm>
