petsc on mac os x
Tahar Amari amari at cpht.polytechnique.fr
Fri May 15 09:45:21 CDT 2009
Hello Sean
Thank you very much for this help.
I cannot see in the configure  anything about MPI. Do you mean
that you do need to link with MPI , and this will be only at the link
of your application ?
Many thanks again
Tahar
Le 15 mai 09 à 16:39, Sean Dettrick a écrit :
> I configured petsc-2.3.3-p10 on OSX 10.5 using an openmpi built with
> gcc 4.0.1 gcc compiler.  It works.  The petsc config flags were:
> --with-matlab=0 --with-shared=0 --with-dynamic=0 --with-fortran=0
> I believe that --with-dynamic=0 is important on OSX.
> Also if you happen to have intel MKL:
> --with-blas-lapack-dir=/Library/Frameworks/Intel_MKL.framework/
> Libraries/32
> I hope that helps.
> Sean
> On May 15, 2009, at 1:41 AM, Tahar Amari wrote:
>> Hello ,
>> I am a new petsc user. I am trying to built petsc on mac os 10
>> (10.4 and 10.5), but
>> always have errors.
>> Has anyone already built petsc for MAC OS X (any version of petsc
>> or mac os x) .
>> If yes I would be grateful to get the configure options and the
>> minimum requirements.
>> If it is not possible to built it  I would also appreciate to know
>> it.
>> Thank you very much
>> Tahar
>> T. Amari
>> Centre de Physique Theorique
>> Ecole Polytechnique
>> 91128 Palaiseau Cedex France
>> tel : 33 1 69 33 42 52
>> fax: 33 1 69 33 30 08
>> email: <mailto:amari at cpht.polytechnique.fr>
>> URL : http://www.cpht.polytechnique.fr/cpht/amari
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090515/973feb76/attachment.htm>
