petsc4py fails to configure with my own lapack/blas
Lisandro Dalcin dalcinl at gmail.com
Thu Jun 4 17:13:11 CDT 2009
This smells to a 32/64 bit libs mismatch, or a g77/g95/gfortran
mismatch. Addionally, could you try to run 'ldd' on core PETSc libs
and on the PETSc.so extension module?
On Thu, Jun 4, 2009 at 7:00 PM, Ondrej Certik <ondrej at certik.cz> wrote:
> Hi,
> I am trying to build petsc-3.0.0 inside Sage, for which I want it to
> use Sage's lapack and blas.
> Here is what I do:
> ./configure --prefix="$SAGE_LOCAL"
> --with-blas-lapack-dir="$SAGE_LOCAL/lib" --CFLAGS="-fPIC"
> --CXXFLAGS="-fPIC"
> (The -fPIC flags are necessary, otherwise petsc4py fails to build on
> 64bit when linking with petsc -- that might be another bug)
> When I execute the above line, I get:
>         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for details):
> You set a value for --with-blas-lapack-dir=<dir>, but
> /home/ondrej/ext/spd-3.4.2spd3-ubuntu-64bit/local/lib cannot be used
> and a configure.log is attached. I also tried:
> --with-lapack-lib="$SAGE_LOCAL/lib/liblapack.a"
> --with-blas-lib="$SAGE_LOCAL/lib/libblas.a" --CFLAGS="-fPIC"
> --CXXFLAGS="-fPIC"
> but I got the same result. So as a workaround, I configure it with:
> ./configure --prefix="$SAGE_LOCAL" --with-blas-lapack-dir="/usr/lib"
> --CFLAGS="-fPIC" --CXXFLAGS="-fPIC"
> which works fine, petsc4py also installs fine, but unfortunately it
> doesn't import:
> http://code.google.com/p/femhub/issues/detail?id=30
> which I suspect is due to the wrong lapack and blas during petsc build
> (but I may be wrong, maybe it's another bug).
> Does anyone knows what else I can try to get it to work?
> Thanks,
> Ondrej
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
