petsc4py fails to configure with my own lapack/blas
Ondrej Certik ondrej at certik.cz
Thu Jun 4 17:00:52 CDT 2009
I am trying to build petsc-3.0.0 inside Sage, for which I want it to
use Sage's lapack and blas.
Here is what I do:
./configure --prefix="$SAGE_LOCAL"
--with-blas-lapack-dir="$SAGE_LOCAL/lib" --CFLAGS="-fPIC"
--CXXFLAGS="-fPIC"
(The -fPIC flags are necessary, otherwise petsc4py fails to build on
64bit when linking with petsc -- that might be another bug)
When I execute the above line, I get:
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
You set a value for --with-blas-lapack-dir=<dir>, but
/home/ondrej/ext/spd-3.4.2spd3-ubuntu-64bit/local/lib cannot be used
and a configure.log is attached. I also tried:
--with-lapack-lib="$SAGE_LOCAL/lib/liblapack.a"
--with-blas-lib="$SAGE_LOCAL/lib/libblas.a" --CFLAGS="-fPIC"
--CXXFLAGS="-fPIC"
but I got the same result. So as a workaround, I configure it with:
./configure --prefix="$SAGE_LOCAL" --with-blas-lapack-dir="/usr/lib"
--CFLAGS="-fPIC" --CXXFLAGS="-fPIC"
which works fine, petsc4py also installs fine, but unfortunately it
doesn't import:
http://code.google.com/p/femhub/issues/detail?id=30
which I suspect is due to the wrong lapack and blas during petsc build
(but I may be wrong, maybe it's another bug).
Does anyone knows what else I can try to get it to work?
Ondrej
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090604/e770b9ad/attachment-0001.bin>
