VecView behaviour
Tue Jun 2 16:07:22 CDT 2009
    Hmm, it sounds like the difference between local "ghosted" vectors
and the global parallel vectors. But I do not understand why any of
the local vector entries would be zero.
Doesn't the vector X that is passed into KSP (or SNES) have the global
entries and uniquely define the solution? Why is viewing that not right?
    Barry
On Jun 2, 2009, at 3:23 PM, Andreas Grassl wrote:
> Barry Smith schrieb:
>> On May 29, 2009, at 4:34 AM, Andreas Grassl wrote:
>>> Hello,
>>> I'm working with the PCNN preconditioner and hence with
>>> ISLocalToGlobalMapping.
>>> After solving I want to write the solution to an ASCII-file where
>>> only
>>> the
>>> values belonging to the "external" global numbering are given and
>>> not
>>> followed
>>> by the zeros.
>> What do you mean? What parts of the vector do you want?
> I want the first actdof entries
> actdof is the number of DOF the system has.
> the values of indices is in the range of 0 to actdof-1.
> I create the mapping by
> ISLocalToGlobalMappingCreate(commw,ind_length,indices,&gridmapping);
> Due to the "existence" of interface DOF's the sum over all
> ind_length is
> greather than actdof, namely the size of the Vectors, but only
> actdof entries of
> this Vector are nonzero, if I view it.
>>> Currently I'm giving this commands:
>>> ierr =
>>> PetscViewerSetFormat
>>> (viewer,PETSC_VIEWER_ASCII_SYMMODU);CHKERRQ(ierr);
>>> ierr = VecView(X,viewer);CHKERRQ(ierr);
> I hope you got an idea, what problem I have.
> Cheers,
> ando
> \ /      ASCII Ribbon
>  X    against HTML email
