VecView behaviour
Andreas Grassl Andreas.Grassl at student.uibk.ac.at
Tue Jun 2 15:23:37 CDT 2009
Barry Smith schrieb:
> On May 29, 2009, at 4:34 AM, Andreas Grassl wrote:
>> Hello,
>> I'm working with the PCNN preconditioner and hence with
>> ISLocalToGlobalMapping.
>> After solving I want to write the solution to an ASCII-file where only
>> the
>> values belonging to the "external" global numbering are given and not
>> followed
>> by the zeros.
> What do you mean? What parts of the vector do you want?
I want the first actdof entries
actdof is the number of DOF the system has.
the values of indices is in the range of 0 to actdof-1.
I create the mapping by
ISLocalToGlobalMappingCreate(commw,ind_length,indices,&gridmapping);
Due to the "existence" of interface DOF's the sum over all ind_length is
greather than actdof, namely the size of the Vectors, but only actdof entries of
this Vector are nonzero, if I view it.
>> Currently I'm giving this commands:
>> ierr =
>> PetscViewerSetFormat(viewer,PETSC_VIEWER_ASCII_SYMMODU);CHKERRQ(ierr);
>> ierr = VecView(X,viewer);CHKERRQ(ierr);
I hope you got an idea, what problem I have.
Cheers,
ando
 \ /      ASCII Ribbon
  X    against HTML email
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090602/e2e720ad/attachment.pgp>
