shared libraries for PETSc 3.0.0-p2 + Hypre
Fri Jan 30 14:14:34 CST 2009
We build external packages minimally only. So the PETSc shared
libraries will link with most of the external .a libraries. This works
fine for us.
To build shared hypre library - you can try the following and see if
it works:
cd $PETSC_DIR
make SHLIBS=libHYPRE shared
Satish
On Fri, 30 Jan 2009, Shao-Ching Huang wrote:
> Hi,
> I am trying to build shared library version of PETSC 3.0.0-p2 with
> Hypre (Fedora 10 Linux on x86_64).
> With "configure --with-shared=1 ...", it does build shared libraries
> for PETSC, but the Hypre part is still static. The file
> externalpackages/hypre-2.4.0b/src/config.log shows that
> "--enable-shared" (for configuring Hypre) is not there.
> Is there a way to build shared libraries for Hypre from PETSc's
> configure command line?
> Thanks.
> Shao-Ching
> My complete PETSc configure command:
> ./config/configure.py  --with-debugging=1 --with-shared=1 \
> --with-cc=mpicc --with-fc=mpif90 --with-cxx=mpicxx        \
> --with-blas-lapack-dir=/usr/lib64                         \
> --download-hypre=yes
> The first few lines of externalpackages/hypre-2.4.0b/src/config.log
> (reformatted):
> $ ./configure
> --prefix=/home/schuang/local/petsc-3.0.0-p2-shared/linux-gnu-c-debug
> CC=mpicc -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -g3
> CXX=mpicxx -Wall -Wwrite-strings -Wno-strict-aliasing -g -fPIC
> F77=mpif90 -fPIC -Wall -Wno-unused-variable -g
> --with-MPI-include=/usr/include/openmpi/1.2.4-gcc/64
> --with-MPI-lib-dirs= --with-MPI-libs=nsl rt --with-blas-libs=
> --with-blas-lib-dir= --with-lapack-libs= --with-lapack-lib-dir=
> --with-blas=yes --with-lapack=yes --without-babel --without-mli
> --without-fei --without-superlu
