shared libraries for PETSc 3.0.0-p2 + Hypre
Shao-Ching Huang schuang at ats.ucla.edu
Fri Jan 30 14:06:56 CST 2009
I am trying to build shared library version of PETSC 3.0.0-p2 with
Hypre (Fedora 10 Linux on x86_64).
With "configure --with-shared=1 ...", it does build shared libraries
for PETSC, but the Hypre part is still static. The file
externalpackages/hypre-2.4.0b/src/config.log shows that
"--enable-shared" (for configuring Hypre) is not there.
Is there a way to build shared libraries for Hypre from PETSc's
configure command line?
Thanks.
Shao-Ching
My complete PETSc configure command:
./config/configure.py  --with-debugging=1 --with-shared=1 \
--with-cc=mpicc --with-fc=mpif90 --with-cxx=mpicxx        \
--with-blas-lapack-dir=/usr/lib64                         \
--download-hypre=yes
The first few lines of externalpackages/hypre-2.4.0b/src/config.log
(reformatted):
$ ./configure
--prefix=/home/schuang/local/petsc-3.0.0-p2-shared/linux-gnu-c-debug
CC=mpicc -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -g3
CXX=mpicxx -Wall -Wwrite-strings -Wno-strict-aliasing -g -fPIC
F77=mpif90 -fPIC -Wall -Wno-unused-variable -g
--with-MPI-include=/usr/include/openmpi/1.2.4-gcc/64
--with-MPI-lib-dirs= --with-MPI-libs=nsl rt --with-blas-libs=
--with-blas-lib-dir= --with-lapack-libs= --with-lapack-lib-dir=
--with-blas=yes --with-lapack=yes --without-babel --without-mli
--without-fei --without-superlu
