MatCreateMPIAIJWithSplitArrays
Panyasantisuk Jarunan Jarunan.Panyasantisuk at eleves.ec-nantes.fr
Fri Jan 23 10:07:03 CST 2009
I have tried to upgrade to 3.0.0, I could compile the program with
MatCreateMPIAIJWithSplitArrays() but somehow cause of the configuration
I cannot execute the program. Anyway, does not it work with petsc-2.3.3?
Is there an equivalent mechanism for MatCreateMPIAIJWithSplitArrays()
(Like MatMPIAIJSetPreallocationCSR() for MatCreateMPIAIJWithArrays()) ?
Thank you very much
Jarunan
Jarunan PANYASANTISUK
MSc. in Computational Mechanics
Erasmus Mundus Master Program
Ecole Centrale de Nantes
1, rue de la noë, 44321 NANTES, FRANCE
Matthew Knepley <knepley at gmail.com> a écrit :
> On Thu, Jan 15, 2009 at 9:42 AM, Panyasantisuk Jarunan <
> Jarunan.Panyasantisuk at eleves.ec-nantes.fr> wrote:
>> When I create a matrix with MatCreateMPIAIJWithSplitArrays, as it doesn't
>> copy the values so I have to use MatSetValues to set the internal value?
> 1) You should upgrade to 3.0.0
> 2) You should not have to call MatSetValues(). It will use the arrays you
> provide.
>  Matt
>> Barry Smith <bsmith at mcs.anl.gov> a Ã(c)crit :
>>>   You should be able to use MatCreateMPIAIJWithSplitArrays(),
>>>  MatCreateMPIAIJWithArrays() or MatMPIAIJSetPreallocationCSR()
>>> from Fortran. Are you using PETSc 3.0.0?
>>>   The arguments for MatCreateMPIAIJWithArrays() or
>>>  MatMPIAIJSetPreallocationCSR() have the same meaning
>>> (in fact MatCreateMPIAIJWithArrays() essentially calls
>>>  MatCreateMPIAIJWithArrays()).
>>>   Barry
>>> On Jan 14, 2009, at 7:38 AM, Panyasantisuk Jarunan wrote:
>>>  Oh, I could not use MatCreateMPIAIJWithArrays either but the  mechanism
>>>> below works.
>>>>    call MatCreate(PETSC_COMM_WORLD,D,ierr)
>>>>    call MatSetSizes(D,N,N,PETSC_DETERMINE,PETSC_DETERMINE,
>>>>   $     ierr)
>>>>    call MatSetType(D,MATMPIAIJ,ierr) ! to set type a parallel matrix
>>>>    call MatSetFromOptions(D,ierr)
>>>>    call MatMPIAIJSetPreallocationCSR(D,pointer,Column,v,ierr)
>>>> Where pointer is start-row indices a
>>>>    Column is local column indices
>>>>    v is value
>>>> Is there the different beteween the start-row indices in
>>>>  MatMPIAIJSetPreallocationCSR and row indices in
>>>> Regards,
>>>> Jarunan
>>>> Hello,
>>>> To define a matrix with arrays, I cannot use
>>>>  MatCreateMPIAIJWithSplitArrays in my program which is written in
>>>> Fortran:
>>>>    call MatCreateMPIAIJWithSplitArrays(PETSC_COMM_WORLD,N,N,
>>>>   $     PETSC_DETERMINE,PETSC_DETERMINE,pointer,column,v,opointer,
>>>>   $     oColumn,ov,D,ierr)
>>>> The error is
>>>> F:246: undefined reference to `matcreatempiaijwithsplitarrays_'
>>>> I could use MatCreateMPIAIJWithArrays but the off diagonal values  are
>>>> missing with this command.
>>>> I would be appreciate for any advice. Thank you before hand.
>>>> Regards,
>>>> Jarunan
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
