Installation
Panyasantisuk Jarunan Jarunan.Panyasantisuk at eleves.ec-nantes.fr
Mon Jan 19 06:43:08 CST 2009
I have upgraded Petsc to 3.0.0. For the configuration(1) I got C++
error. Anyway I could do make but make test failed for Fortran
example(2).
Do you have any idea? I would be appreciate for any advise. Thank you
very much.
Jarunan
- - - - (1) - - - -
./config/configure.py --with-cc=/usr/local/mpich-ifc-ssh/bin/mpicc
--with-fc=/usr/local/mpich-ifc-ssh/bin/mpif90
--download-f-blas-lapack=1 --download-hypre=1 --download-ml=1
--with-cxx=icpc --with-mpi-dir=/usr/local/mpich-ifc-ssh --with-shared=0
             Configuring PETSc to compile on your system
=================================================================================        Warning: [with-mpi-dir] option is used along with options: ['with-cc', 'with-fc', 'with-cxx']                                              This prevents configure from picking up MPI compilers from specified mpi-dir.        Sugest using *only* [with-mpi-dir] option - and no other compiler option.        This way - mpi compilers from /usr/local/mpich-ifc-ssh are used.        =================================================================================                                                          TESTING: CxxMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:598)
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
C++ error! MPI_Finalize() could not be located!
- - - - (2) - - - -
make test
Running test examples to verify correct installation
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
MPI process
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2
MPI processes
Graphics example src/snes/examples/tutorials/ex19 run successfully with
1 MPI process
Error running Fortran example src/snes/examples/tutorials/ex5f with 1
MPI process
See http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
0 - <NO ERROR MESSAGE> : Could not convert index 1140850688 into a pointer
The index may be an incorrect argument.
Possible sources of this problem are a missing "include 'mpif.h'",
a misspelled MPI object (e.g., MPI_COM_WORLD instead of MPI_COMM_WORLD)
or a misspelled user variable for an MPI object (e.g.,
com instead of comm).
[0]  Aborting program !
[0] Aborting program!
p0_31302:  p4_error: : 9039
Completed test examples
Jarunan PANYASANTISUK
MSc. in Computational Mechanics
Erasmus Mundus Master Program
Ecole Centrale de Nantes
1, rue de la noë, 44321 NANTES, FRANCE
Matthew Knepley <knepley at gmail.com> a écrit :
> On Thu, Jan 15, 2009 at 9:42 AM, Panyasantisuk Jarunan <
> Jarunan.Panyasantisuk at eleves.ec-nantes.fr> wrote:
>> When I create a matrix with MatCreateMPIAIJWithSplitArrays, as it doesn't
>> copy the values so I have to use MatSetValues to set the internal value?
> 1) You should upgrade to 3.0.0
> 2) You should not have to call MatSetValues(). It will use the arrays you
> provide.
>  Matt
>> Barry Smith <bsmith at mcs.anl.gov> a Ã(c)crit :
>>>   You should be able to use MatCreateMPIAIJWithSplitArrays(),
>>>  MatCreateMPIAIJWithArrays() or MatMPIAIJSetPreallocationCSR()
>>> from Fortran. Are you using PETSc 3.0.0?
>>>   The arguments for MatCreateMPIAIJWithArrays() or
>>>  MatMPIAIJSetPreallocationCSR() have the same meaning
>>> (in fact MatCreateMPIAIJWithArrays() essentially calls
>>>  MatCreateMPIAIJWithArrays()).
>>>   Barry
>>> On Jan 14, 2009, at 7:38 AM, Panyasantisuk Jarunan wrote:
>>>  Oh, I could not use MatCreateMPIAIJWithArrays either but the  mechanism
>>>> below works.
>>>>    call MatCreate(PETSC_COMM_WORLD,D,ierr)
>>>>    call MatSetSizes(D,N,N,PETSC_DETERMINE,PETSC_DETERMINE,
>>>>   $     ierr)
>>>>    call MatSetType(D,MATMPIAIJ,ierr) ! to set type a parallel matrix
>>>>    call MatSetFromOptions(D,ierr)
>>>>    call MatMPIAIJSetPreallocationCSR(D,pointer,Column,v,ierr)
>>>> Where pointer is start-row indices a
>>>>    Column is local column indices
>>>>    v is value
>>>> Is there the different beteween the start-row indices in
>>>>  MatMPIAIJSetPreallocationCSR and row indices in
>>>> Regards,
>>>> Jarunan
>>>> Hello,
>>>> To define a matrix with arrays, I cannot use
>>>>  MatCreateMPIAIJWithSplitArrays in my program which is written in
>>>> Fortran:
>>>>    call MatCreateMPIAIJWithSplitArrays(PETSC_COMM_WORLD,N,N,
>>>>   $     PETSC_DETERMINE,PETSC_DETERMINE,pointer,column,v,opointer,
>>>>   $     oColumn,ov,D,ierr)
>>>> The error is
>>>> F:246: undefined reference to `matcreatempiaijwithsplitarrays_'
>>>> I could use MatCreateMPIAIJWithArrays but the off diagonal values  are
>>>> missing with this command.
>>>> I would be appreciate for any advice. Thank you before hand.
>>>> Regards,
>>>> Jarunan
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
