compiling petsc2-3.3-p15 against mvapich-0.9.9
Wed Jan 21 18:40:44 CST 2009
Each time - do you see binary chars at the end of configure.log -
after the _access test?
I don't know why this would happen.
Perhaps you can try with the same configure options - and send in the
configure.log [petsc-maint at mcs.anl.gov] for us to comapre.
Satish
On Wed, 21 Jan 2009, Matt Funk wrote:
> I tried it multiple from a fresh tarball each time. Same thing everytime.
> Did you mean try with different configure options? If so, which ones did you
> have in mind?
> thanks
> matt
> On Wednesday 21 January 2009, Satish Balay wrote:
> > Not sure what the issue is. I see the configure.log [from the rejected
> > e-mail] - there are some binary chars at the end of the file.
> > Perhaps you can retry and see? [after rm *.log]. If you still have
> > issues - send configure.log to petsc-maint at mcs.anl.gov
> > Satish
> > > Hi,
> > > i was wondering if there is any issues with compiling petsc based on
> > > mvapich-0.9.9. I tells me that it is unable to configure with given
> > > options. I configure as such:
> > > ./config/configure.py
> > > --with-mpi-include=/usr/mpi/mvapich-0.9.9/gcc/include
> > > --with-mpi-lib=/usr/mpi/mvapich-0.9.9/gcc/lib/libmpich.a
> > > --with-debugging=0 --with-log=0 --with-cc=gcc --with-fc=gfortran
> > > --download-f-blas-lapack=1 --download-superlu=1 --download-superlu_dist=1
> > > --download-spooles=1 --download-hypre=hypre-2.4.0b.tar.gz
> > > I can compile  petsc against the mvapich2 libraries just fine.
> > > thanks
> > > matt
