compiling petsc2-3.3-p15 against mvapich-0.9.9
Matt Funk mafunk at nmsu.edu
Wed Jan 21 18:30:20 CST 2009
I tried it multiple from a fresh tarball each time. Same thing everytime.
Did you mean try with different configure options? If so, which ones did you
have in mind?
thanks
matt
On Wednesday 21 January 2009, Satish Balay wrote:
> Not sure what the issue is. I see the configure.log [from the rejected
> e-mail] - there are some binary chars at the end of the file.
> Perhaps you can retry and see? [after rm *.log]. If you still have
> issues - send configure.log to petsc-maint at mcs.anl.gov
> Satish
> On Wed, 21 Jan 2009, Matt Funk wrote:
> > Hi,
> > i was wondering if there is any issues with compiling petsc based on
> > mvapich-0.9.9. I tells me that it is unable to configure with given
> > options. I configure as such:
> > ./config/configure.py
> > --with-mpi-include=/usr/mpi/mvapich-0.9.9/gcc/include
> > --with-mpi-lib=/usr/mpi/mvapich-0.9.9/gcc/lib/libmpich.a
> > --with-debugging=0 --with-log=0 --with-cc=gcc --with-fc=gfortran
> > --download-f-blas-lapack=1 --download-superlu=1 --download-superlu_dist=1
> > --download-spooles=1 --download-hypre=hypre-2.4.0b.tar.gz
> > I can compile  petsc against the mvapich2 libraries just fine.
> > thanks
> > matt
