PetscValidHeaderSpecific()
Tue Jan 6 16:48:58 CST 2009
    The most likely cause is memory corruption. The best way to solve
this problem is to run on linux using
valgrind (valgrind.org), the second best is to run with -malloc_debug
and see if any messages come out
    Barry
On Jan 6, 2009, at 4:44 PM, (Rebecca) Xuefei YUAN wrote:
> Hi,
> I did have error information as at the end of this email, and I
> found the error was a function called PetscValidHeaderSpecific(), is
> there anything wrong with it?
> Thanks a lot!
> R
> [0]PETSC ERROR: Invalid argument!
> [0]PETSC ERROR: Wrong type of object: Parameter # 1!
> [0]PETSC ERROR: ----------------------------------------
> [0]PETSC ERROR: Petsc Release Version 3.0.0, Patch 0, Fri Dec 19
> 22:02:38 CST 2008
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: ./oreggt on a cygwin-c- named YUAN_WORK by Rebecca
> Tue Jan 6 17:29:59 2009
> [0]PETSC ERROR: Libraries linked from /home/Rebecca/soft/petsc-3.0.0-
> p0/cygwin-c-debug/lib
> [0]PETSC ERROR: Configure run at Mon Jan 5 13:50:14 2009
> [0]PETSC ERROR: Configure options --with-cc=gcc --download-f-blas-
> lapack=1 --download-mpich=1 --useThreads=0 --with-shared=0
> [0]PETSC ERROR: MatDestroy() line 766 in src/mat/interface/matrix.c
> [0]PETSC ERROR: PCDestroy() line 88 in src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: KSPDestroy() line 647 in src/ksp/ksp/interface/itfun.c
> [0]PETSC ERROR: SNESDestroy() line 1378 in src/snes/interface/snes.c
> [0]PETSC ERROR: PetscObjectDestroy() line 172 in src/sys/objects/
> destroy.c
> [0]PETSC ERROR: DMMGDestroy() line 220 in src/snes/utils/damg.c
> [0]PETSC ERROR: main() line 55 in oreggt.c
> application called MPI_Abort(MPI_COMM_WORLD,62) - process 0[unset]:
> aborting job:
