PetscValidHeaderSpecific()
(Rebecca) Xuefei YUAN xy2102 at columbia.edu
Tue Jan 6 16:44:16 CST 2009
I did have error information as at the end of this email, and I found
the error was a function called PetscValidHeaderSpecific(), is there
anything wrong with it?
Thanks a lot!
R
[0]PETSC ERROR: Invalid argument!
[0]PETSC ERROR: Wrong type of object: Parameter # 1!
[0]PETSC ERROR: ----------------------------------------
[0]PETSC ERROR: Petsc Release Version 3.0.0, Patch 0, Fri Dec 19
22:02:38 CST 2008
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: ./oreggt on a cygwin-c- named YUAN_WORK by Rebecca Tue
Jan 6 17:29:59 2009
[0]PETSC ERROR: Libraries linked from
/home/Rebecca/soft/petsc-3.0.0-p0/cygwin-c-debug/lib
[0]PETSC ERROR: Configure run at Mon Jan 5 13:50:14 2009
[0]PETSC ERROR: Configure options --with-cc=gcc
--download-f-blas-lapack=1 --download-mpich=1 --useThreads=0
--with-shared=0
[0]PETSC ERROR: MatDestroy() line 766 in src/mat/interface/matrix.c
[0]PETSC ERROR: PCDestroy() line 88 in src/ksp/pc/interface/precon.c
[0]PETSC ERROR: KSPDestroy() line 647 in src/ksp/ksp/interface/itfun.c
[0]PETSC ERROR: SNESDestroy() line 1378 in src/snes/interface/snes.c
[0]PETSC ERROR: PetscObjectDestroy() line 172 in src/sys/objects/destroy.c
[0]PETSC ERROR: DMMGDestroy() line 220 in src/snes/utils/damg.c
[0]PETSC ERROR: main() line 55 in oreggt.c
application called MPI_Abort(MPI_COMM_WORLD,62) - process 0[unset]:
aborting job:
