Debug in parallel
Mon Apr 20 16:03:51 CDT 2009
Generally X11 settings different for different senarios - so the
default is not correct for some folks..
You can try -start_in_debugger -display :0.0
Satish
On Mon, 20 Apr 2009, (Rebecca) Xuefei YUAN wrote:
> Hi,
> I am running a petsc code on my local machine with two processors, and would
> like to debug it in parallel.
> When I use the option "-start_in_debug", there is only one gdb window coming
> out, is there something wrong? How could I have two gdb windows each on one
> processor?
> Thanks,
> Rebecca
