Matrixfree modification
Johann Schlamp schlamp at in.tum.de
Wed Oct 29 17:01:18 CDT 2008
Johann Schlamp wrote:
> Matthew Knepley wrote:
>> On Tue, Oct 28, 2008 at 4:35 PM, Johann Schlamp <schlamp at in.tum.de> wrote:
>>> Barry Smith wrote:
>>>>    If you have the "matrix-based" version that you can run on the same
>>>> problem then
>>>> look at the residuals computed in the 0th and 1st step of the Krylov
>>>> method
>>>> to see how they are different in the two runs.
>>> The residuals in the 0th and 1st step of the linear solver are
>>> 0.00363413
>>> 0.00189276
>>> for the "matrix-based" version, and
>>> 0.00363413
>>> 1.27858e-17
>> No this looks wrong. Shouldn't these be identical? It looks like you
>> are wiping out the input vector instead.
>>    Matt
After some extended testing, I think I really messed up the input vector
somehow. I dare say I can take it from here. If not - I know where to
get competent support. :)
Thanks for all help!
Johann
> Yes, they should be identical. That's excactly the point.
> My naive interpretation was that maybe only the residual's calculation
> is wrong.
> After thinking again, I believe I have misunderstood Barry's hint on
> copying the 'u'.
> Apparently, the user-provided Jacobian calculation method gets a
> different input than my customized MatMult method called within KSP on
> my matrixfree context. But they are both needed for my approach, right?
> I haven't thought of that in advance, so it will take me some time to
> rewrite the code. I will report again tomorrow (it's 11 o'clock pm at my
> site).
> Thanks for your help!
> Johann
>>> for the matrix-free version. That's definitely smaller than epsilon, so
>>> it converges. By the way, the "matrix-based" version doesn't converge
>>> either, as I was not using a preconditioner for getting comparable results.
>>> Simply thought: the residual is in the magnitude of machine accuracy, so
>>> I would have concluded that the calculation of the residual (y-A*x)
>>> results in zero with respect to some rounding errors. Unfortunately, I
>>> don't completely understand the PETSc code for calculating the residual
>>> and therfore cannot verify it for my new matrix structure.
>>>>    Perhaps your matrix-free is corrupting memory? Run with -malloc_debug
>>>> and put a CHKMEMQ; at the end of your matrix free multiply. Or better
>>>> run through
>>>> valgrind,. www.valgrind.org
>>> Interesting thought! I will check this tomorrow.
>>> Johann
>>>> On Oct 28, 2008, at 3:39 PM, Johann Schlamp wrote:
>>>>> Thanks for your reply, Barry!
>>>>> Barry Smith wrote:
>>>>>>   Your general approach seems fine. I would put a break point in
>>>>>> your MatMult routine for a tiny problem and verify that the input
>>>>>> vector for u and
>>>>>> x are what you expect (and then at the end of the function make sure
>>>>>> the
>>>>>> output y is what you expect).
>>>>> I have already done this, everything is as expected.
>>>>>>   Here is my guess: The matrix vector product is J(u)*x; when your
>>>>>> calculation
>>>>>> is done you need to use the correct u value. This is the vector that is
>>>>>> passed into your "empty method as user-provided Jacobian method".
>>>>>> In your "empty method as user-provided Jacobian method" you should make
>>>>>> a copy of this vector so that you have it for each of the matrix
>>>>>> vector products.
>>>>>> At each Newton step your "empty method as user-provided Jacobian
>>>>>> method"
>>>>>> will be called and you will copy the new value of u over.
>>>>> It took me some time to understand what you mean. But after that I got
>>>>> excited trying it out. :)
>>>>> It definitely had some effect on the nonlinear solution, but the linear
>>>>> solver still finishes after one iteration with the way too small
>>>>> residual norm.
>>>>> Anyway, thanks for the anticipated bugfix!
>>>>> Do you have any further suggestions?
>>>>> Best regards,
>>>>> Johann
>>>>>> On Oct 28, 2008, at 10:08 AM, Johann Schlamp <schlamp at in.tum.de> wrote:
>>>>>>> Hello folks,
>>>>>>> I have to implement some advanced matrixfree calculation.
>>>>>>> Usually, we use our own analytical method for calculating the Jacobian
>>>>>>> matrix and provide it via SNESSetJacobian(). For complex problems, the
>>>>>>> global matrix takes too much memory. So here's the idea:
>>>>>>> First, I set some empty method as user-provided Jacobian method.
>>>>>>> After a
>>>>>>> corresponding call, SNES hopefully thinks the Jacobian matrix got
>>>>>>> calculated right. Then it will use it in some multiplication like
>>>>>>> y=A*x.
>>>>>>> For that I created the matrix A with MatCreateShell() and set up my
>>>>>>> own
>>>>>>> MatMult method. This new method iterates over my grid, calculates
>>>>>>> local
>>>>>>> Jacobians, multiplies them with the corresponding part of the vector x
>>>>>>> and writes them into y. After this full iteration, it should look
>>>>>>> like I
>>>>>>> had the full global Jacobian and multiplied it with the full vector x.
>>>>>>> In y, the result will be the same.
>>>>>>> The matrix A and the empty Jacobian method are set through
>>>>>>> SNESSetJacobian().
>>>>>>> I have implemented some unittests for generally proofing the idea,
>>>>>>> seems
>>>>>>> to work.
>>>>>>> But if I run a complete simulation, the KSP converges after the first
>>>>>>> iteration with a residual norm of about 1.0e-18, which is
>>>>>>> definitely not
>>>>>>> right.
>>>>>>> Now my question: does this procedure make sense at all, and if so - is
>>>>>>> it possible that just the calculation of the residual norm goes wrong
>>>>>>> due to my new matrix structure? I searched the PETSc code, but I
>>>>>>> wasn't
>>>>>>> able to find a proof or solution for that.
>>>>>>> Any help would be appreciated.
>>>>>>> Best regards,
>>>>>>> Johann Schlamp
