Matrixfree modification
Johann Schlamp schlamp at in.tum.de
Tue Oct 28 17:28:43 CDT 2008
Matthew Knepley wrote:
> On Tue, Oct 28, 2008 at 4:35 PM, Johann Schlamp <schlamp at in.tum.de> wrote:
>> Barry Smith wrote:
>>>    If you have the "matrix-based" version that you can run on the same
>>> problem then
>>> look at the residuals computed in the 0th and 1st step of the Krylov
>>> method
>>> to see how they are different in the two runs.
>> The residuals in the 0th and 1st step of the linear solver are
>> 0.00363413
>> 0.00189276
>> for the "matrix-based" version, and
>> 0.00363413
>> 1.27858e-17
> No this looks wrong. Shouldn't these be identical? It looks like you
> are wiping out the input vector instead.
>    Matt
Yes, they should be identical. That's excactly the point.
My naive interpretation was that maybe only the residual's calculation
is wrong.
After thinking again, I believe I have misunderstood Barry's hint on
copying the 'u'.
Apparently, the user-provided Jacobian calculation method gets a
different input than my customized MatMult method called within KSP on
my matrixfree context. But they are both needed for my approach, right?
I haven't thought of that in advance, so it will take me some time to
rewrite the code. I will report again tomorrow (it's 11 o'clock pm at my
site).
Thanks for your help!
Johann
>> for the matrix-free version. That's definitely smaller than epsilon, so
>> it converges. By the way, the "matrix-based" version doesn't converge
>> either, as I was not using a preconditioner for getting comparable results.
>> Simply thought: the residual is in the magnitude of machine accuracy, so
>> I would have concluded that the calculation of the residual (y-A*x)
>> results in zero with respect to some rounding errors. Unfortunately, I
>> don't completely understand the PETSc code for calculating the residual
>> and therfore cannot verify it for my new matrix structure.
>>>    Perhaps your matrix-free is corrupting memory? Run with -malloc_debug
>>> and put a CHKMEMQ; at the end of your matrix free multiply. Or better
>>> run through
>>> valgrind,. www.valgrind.org
>> Interesting thought! I will check this tomorrow.
>> Johann
>>> On Oct 28, 2008, at 3:39 PM, Johann Schlamp wrote:
>>>> Thanks for your reply, Barry!
>>>> Barry Smith wrote:
>>>>>   Your general approach seems fine. I would put a break point in
>>>>> your MatMult routine for a tiny problem and verify that the input
>>>>> vector for u and
>>>>> x are what you expect (and then at the end of the function make sure
>>>>> the
>>>>> output y is what you expect).
>>>> I have already done this, everything is as expected.
>>>>>   Here is my guess: The matrix vector product is J(u)*x; when your
>>>>> calculation
>>>>> is done you need to use the correct u value. This is the vector that is
>>>>> passed into your "empty method as user-provided Jacobian method".
>>>>> In your "empty method as user-provided Jacobian method" you should make
>>>>> a copy of this vector so that you have it for each of the matrix
>>>>> vector products.
>>>>> At each Newton step your "empty method as user-provided Jacobian
>>>>> method"
>>>>> will be called and you will copy the new value of u over.
>>>> It took me some time to understand what you mean. But after that I got
>>>> excited trying it out. :)
>>>> It definitely had some effect on the nonlinear solution, but the linear
>>>> solver still finishes after one iteration with the way too small
>>>> residual norm.
>>>> Anyway, thanks for the anticipated bugfix!
>>>> Do you have any further suggestions?
>>>> Best regards,
>>>> Johann
>>>>> On Oct 28, 2008, at 10:08 AM, Johann Schlamp <schlamp at in.tum.de> wrote:
>>>>>> Hello folks,
>>>>>> I have to implement some advanced matrixfree calculation.
>>>>>> Usually, we use our own analytical method for calculating the Jacobian
>>>>>> matrix and provide it via SNESSetJacobian(). For complex problems, the
>>>>>> global matrix takes too much memory. So here's the idea:
>>>>>> First, I set some empty method as user-provided Jacobian method.
>>>>>> After a
>>>>>> corresponding call, SNES hopefully thinks the Jacobian matrix got
>>>>>> calculated right. Then it will use it in some multiplication like
>>>>>> y=A*x.
>>>>>> For that I created the matrix A with MatCreateShell() and set up my
>>>>>> own
>>>>>> MatMult method. This new method iterates over my grid, calculates
>>>>>> local
>>>>>> Jacobians, multiplies them with the corresponding part of the vector x
>>>>>> and writes them into y. After this full iteration, it should look
>>>>>> like I
>>>>>> had the full global Jacobian and multiplied it with the full vector x.
>>>>>> In y, the result will be the same.
>>>>>> The matrix A and the empty Jacobian method are set through
>>>>>> SNESSetJacobian().
>>>>>> I have implemented some unittests for generally proofing the idea,
>>>>>> seems
>>>>>> to work.
>>>>>> But if I run a complete simulation, the KSP converges after the first
>>>>>> iteration with a residual norm of about 1.0e-18, which is
>>>>>> definitely not
>>>>>> right.
>>>>>> Now my question: does this procedure make sense at all, and if so - is
>>>>>> it possible that just the calculation of the residual norm goes wrong
>>>>>> due to my new matrix structure? I searched the PETSc code, but I
>>>>>> wasn't
>>>>>> able to find a proof or solution for that.
>>>>>> Any help would be appreciated.
>>>>>> Best regards,
>>>>>> Johann Schlamp
