analyze preconditioned operator?
Thu Oct 9 17:39:00 CDT 2008
On Thu, Oct 9, 2008 at 5:25 PM, Matt Funk <mafunk at nmsu.edu> wrote:
> Hi Matt,
> so, the basic idea with this code is to apply the pc to each column vector of
> the matrix? Is that right?
No, that is what KSPGetExplicitOperator() does. This applies the operator in
a matrix-free way.
> Also, in your example: when is myApply actually invoked? I also looked at the
> example listed under the MatShellSetOperation reference page.
When MatMult(A) is called.
  Matt
> Is the function then actually internally called when MatShellSetOperation is
> called, or when KSPSetOperators is called or KSPSolve?
> The reason i am asking is that if it is called when KSPSolve called then there
> is a problem because for the analysis i never call KSPSolve directly.
> thanks
> matt
> On Thursday 09 October 2008, Matthew Knepley wrote:
>> On Thu, Oct 9, 2008 at 4:32 PM, Matt Funk <mafunk at nmsu.edu> wrote:
>> > mmhh,
>> > i think i am missing something. Doesn't PCApply() apply the
>> > preconditioner to a vector? So how would that work (easily) with a
>> > matrix?
>> You do not apply it to the matrix. Here is a skeleton (maybe has mistakes)
>> void myApply(Mat A, Vec x, Vec y) {
>>   MatShellGetContext(A, &ctx);
>>   MatMult(ctx->M, x, ctx->work);
>>   PCApply(ctx->pc, ctx->work, y);
>> MatShellSetOperation(A, MATOP_MULT, myApply)
>>   Matt
>> > matt
>> >> CApply().
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
