Block-smoothers with variable block size
Nicolas Tardieu niko.karin at gmail.com
Thu Mar 20 13:07:00 CDT 2008
Dear PETSc experts,
I am currently designing a multigrid PC that needs to operate on variable
block size matrices. I know PETSc does not support this feature.
So, I will do it "by hand".  Neverthless I would like to be able to use some
smoothers like Jacobi or SOR in their block version.
What is the best solution that would work both in sequential and parallel?
- define some MATSHELL that handle variable block size
    -> will I be able to use in some way a block Jacobi or SOR?
    -> would it be possible to use CSR inside the MATSHELL and manage the
variable blocks.
- use a AIJ matrix and manage the blocks using some indirection mechanism
and reprogram Jacobi or SOR
Thank you,
Nicolas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080320/85514329/attachment.htm>
