Direct LU solver
Hong Zhang hzhang at mcs.anl.gov
Mon Mar 3 09:55:21 CST 2008
Amit,
> Thanks for your response. A couple of follow-up questions -
> I go over the steps
> MatCreate()
> MatSetType(MPIAIJ)
> MatMPIAIJSetPreallocation()
> MatSetType(MATSUPERLU_DIST).
> Even though I want to do the direct LU solves repeatedly (with the same
> matrix), I don't want the program to do LU factorization repeatedly. I hope
> I can get that functionality by using the "SAME_PRECONDITIONER" option
> (along with -ksppreonly), while defining the KSP. When the program does the
> factorization, does it do it in-place or does it allocate new storage ?
allocate new storage unless you call
MatLUFactor() explicitly.
It is done by
  KSPSetUp()
    which calls PCSetUp() -> PCSetUp_LU()
      -> MatLUFactorSymbolic() & MatLUFactorNumeric(
You can do following for reusing factored L and U:
   KSPCreate()
   KSPSetOperators()
   KSPSetFromOptions()
   KSPSetUp()
   while ( num_rhs-- ) {
     KSPSolve(ksp,b,x);
See src/ksp/ksp/examples/tutorials/ex10.c
> After doing the LU factorization, are the other operations such as
> MatMult() preserved ?
Yes.
Hong
> Thanks
> Rgds,
> Amit
>             Satish Balay
>             <balay at mcs.anl.go
>             v>                                                         To
>             Sent by:                  petsc-users at mcs.anl.gov
>             owner-petsc-users                                          cc
>             @mcs.anl.gov
>             No Phone Info                                         Subject
>             Available                 Re: Direct LU solver
>             02/29/2008 02:06
>             PM
>             Please respond to
>                  nl.gov
> On Fri, 29 Feb 2008, Amit.Itagi at seagate.com wrote:
>> My woes continue.  Based on the earlier discussions, I implemented the
>> matrix as
>>  //   Option 1
>>   ierr=MatCreate(PETSC_COMM_WORLD,&A); CHKERRQ(ierr);
>>   ierr=MatSetSizes(A,1,1,2,2); CHKERRQ(ierr);
>>   /*    Option 2
>>   PetscInt d_nnz=1, o_nnz=1;
>>   ierr=MatCreateMPIAIJ(PETSC_COMM_WORLD,1,1,2,2,0,&d_nnz,0,&o_nnz,&A);
>> CHKERRQ(ierr);
>>   /*   Option 3
> ierr=MatCreateMPIAIJ(PETSC_COMM_WORLD,1,1,2,2,0,PETSC_NULL,0,PETSC_NULL,&A);
>>  CHKERRQ(ierr);
>>   ierr=MatSetType(A,MATSUPERLU_DIST); CHKERRQ(ierr);
>>   ierr=MatSetFromOptions(A); CHKERRQ(ierr);
>>   // (After this, I set the values and do the assembly). I then use the
>> direct LU solver.
>> Note: I have a simple 2 by 2 matrix (with non-zero values in all 4
> places).
>> If I use "option 1" (based on Satish's email), the program executes
>> successfully. If instead of "option 1", I use "option 2" or "option 3", I
>> get a crash.
>> If I am not mistaken, options 1 and 3 are the same. Option 2,
> additionally,
>> does a pre-allocation. Am I correct ?
> Nope - Option 3 is same as:
> MatCreate()
> MatSetType(MPIAIJ)
> [i.e first you are setting type as MPIAIJ, and then changing to
> MATSUPERLU_DIST]
> What you want is:
> MatCreate()
> [Ideally you need MatSuerLU_DistSetPreallocation() - but that would be
> same as MatMPIAIJSetPreallocation()]
> Satish
