Direct LU solver
Amit.Itagi at seagate.com Amit.Itagi at seagate.com
Mon Mar 3 08:30:47 CST 2008
Thanks for your response. A couple of follow-up questions -
I go over the steps
MatCreate()
MatSetType(MPIAIJ)
MatMPIAIJSetPreallocation()
MatSetType(MATSUPERLU_DIST).
Even though I want to do the direct LU solves repeatedly (with the same
matrix), I don't want the program to do LU factorization repeatedly. I hope
I can get that functionality by using the "SAME_PRECONDITIONER" option
(along with -ksppreonly), while defining the KSP. When the program does the
factorization, does it do it in-place or does it allocate new storage ?
After doing the LU factorization, are the other operations such as
MatMult() preserved ?
Thanks
Rgds,
Amit
             Satish Balay
             <balay at mcs.anl.go
             v>                                                         To
             Sent by:                  petsc-users at mcs.anl.gov
             owner-petsc-users                                          cc
             @mcs.anl.gov
             No Phone Info                                         Subject
             Available                 Re: Direct LU solver
             02/29/2008 02:06
             PM
             Please respond to
                  nl.gov
On Fri, 29 Feb 2008, Amit.Itagi at seagate.com wrote:
> My woes continue.  Based on the earlier discussions, I implemented the
> matrix as
>  //   Option 1
>   ierr=MatCreate(PETSC_COMM_WORLD,&A); CHKERRQ(ierr);
>   ierr=MatSetSizes(A,1,1,2,2); CHKERRQ(ierr);
>   /*    Option 2
>   PetscInt d_nnz=1, o_nnz=1;
>   ierr=MatCreateMPIAIJ(PETSC_COMM_WORLD,1,1,2,2,0,&d_nnz,0,&o_nnz,&A);
> CHKERRQ(ierr);
>   /*   Option 3
ierr=MatCreateMPIAIJ(PETSC_COMM_WORLD,1,1,2,2,0,PETSC_NULL,0,PETSC_NULL,&A);
>  CHKERRQ(ierr);
>   ierr=MatSetType(A,MATSUPERLU_DIST); CHKERRQ(ierr);
>   ierr=MatSetFromOptions(A); CHKERRQ(ierr);
>   // (After this, I set the values and do the assembly). I then use the
> direct LU solver.
> Note: I have a simple 2 by 2 matrix (with non-zero values in all 4
places).
> If I use "option 1" (based on Satish's email), the program executes
> successfully. If instead of "option 1", I use "option 2" or "option 3", I
> get a crash.
> If I am not mistaken, options 1 and 3 are the same. Option 2,
additionally,
> does a pre-allocation. Am I correct ?
Nope - Option 3 is same as:
MatCreate()
MatSetType(MPIAIJ)
[i.e first you are setting type as MPIAIJ, and then changing to
MATSUPERLU_DIST]
What you want is:
MatCreate()
[Ideally you need MatSuerLU_DistSetPreallocation() - but that would be
same as MatMPIAIJSetPreallocation()]
Satish
