about Dense Matrix Re: several problems about codes Re: how to add a parallel MatMatSolve() function?
Yujie recrusader at gmail.com
Sat Mar 1 13:12:12 CST 2008
However, you have realized A*B(A is AIJ, B is dense matrix) to my knowledge.
PETSc is the Portable, Extensible Toolkit for Scientific
computation, not the Sparse Portable, Extensible Toolkit for Scientific
computation :).
It is easy to realize A*B(A is dense matrix, B is AIJ)?
Yujie
On 3/1/08, Matthew Knepley <knepley at gmail.com> wrote:
> If you want dense matrices, I would suggest PLAPACK/FLAME instead of
> PETSc. We
> specialize in sparse matrices.
>   Thanks,
>     Matt
> On Sat, Mar 1, 2008 at 12:38 PM, Yujie <recrusader at gmail.com> wrote:
> > Dear Barry:
> > I just find MatMatMult() doesn't support Dense Matrix. I want to do A*B
> (A
> > is dense matrix, B is AIJ). I think a possible method is to convert A to
> > AIJ, however, it will take much more memory than using dense matrix, I
> > think. Because AIJ needs to save positions and corresponding values. Do
> you
> > have any good idea? Thanks a lot.
> > Regards,
> > Yujie
> > On 3/1/08, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > On Mar 1, 2008, at 2:01 AM, Yujie wrote:
> > > Dear Barry:
> > > I can't understand several problems as follows about codes. Could you
> give
> > me some explanations? thanks a lot.
> > > 1. About MatGetArray()
> > > I check the codes of PETSc. I find only matrix types, SeqAij and
> MPIDense,
> > support this fnction. If I want to use SuperLU_dist or Spooles. I need
> to
> > convert matrix A into corresponding type
> > > before I call MatMatSolve(). If it is, MatGetArray() doesn't work, I
> > think.
> > >   MatGetArray() is called on B and X, it is not called on A. B and A
> must
> > be dense or the whole thing doesn't make
> > > sense, since X will always end up being dense.
> > > 2. A->hdr.comm should be A->comm?
> > > Yes, for your version of PETSc
> > > 3.
> > > for (i=0; i<N; i++) {
> > > ierr = VecPlaceArray(b,bb + i*m);CHKERRQ(ierr);
> > > ierr = VecPlaceArray(x,xx + i*m);CHKERRQ(ierr);
> > > ierr = MatSolve(A,b,x);CHKERRQ(ierr);
> > > should be
> > > ierr = VecPlaceArray(xx + i*m,x);CHKERRQ(ierr);
> > > MatRestoreArray(B,&xx);
> > > First replace b with bb+i*m, and solve Ax=b, final replace xx+i*m with
> x.
> > > No, you misunderstand what VecPlaceArray() does. The code above will
> solve
> > the columns in the wrong place.
> > > Yes, I did forget the MatRestoreArray(), thanks for pointing that out.
> > >    Barry
> > > After finishing the loop, the code should call MatRestoreArray() to
> > restore matrix B.
> > > Regards,
> > > Yujie
> > > >    Please edit the file src/mat/interface/matrix.c and remove the
> > > > function MatMatSolve(). Replace it with the following two functions,
> > > > then run "make lib shared" in that directory. Please let us know at
> > petsc-maint at mcs.anl.gov
> > > >   if it crashes or produces incorrect
> > > > results.
> > > >     Barry
> > > > #undef __FUNCT__
> > > > #define __FUNCT__ "MatMatSolve_Basic"
> > > > PetscErrorCode PETSCMAT_DLLEXPORT MatMatSolve_Basic(Mat A,Mat B,Mat
> X)
> > > >    PetscErrorCode ierr;
> > > >    Vec            b,x;
> > > >    PetscInt       m,N,i;
> > > >    PetscScalar    *bb,*xx;
> > > >    PetscFunctionBegin;
> > > >    ierr = MatGetArray(B,&bb);CHKERRQ(ierr);
> > > >    ierr = MatGetArray(X,&xx);CHKERRQ(ierr);
> > > >    ierr = MatGetLocalSize(B,&m,PETSC_NULL);CHKERRQ(ierr);  /* number
> > > > local rows */
> > > >    ierr = MatGetSize(B,PETSC_NULL,&N);CHKERRQ(ierr);       /* total
> > > > columns in dense matrix */
> > > >    ierr = VecCreateMPIWithArray(A-
> > > >   >hdr.comm,m,PETSC_DETERMINE,PETSC_NULL,&b);CHKERRQ(ierr);
> > > >   >hdr.comm,m,PETSC_DETERMINE,PETSC_NULL,&x);CHKERRQ(ierr);
> > > >    ierr = VecDestroy(b);CHKERRQ(ierr);
> > > >    ierr = VecDestroy(x);CHKERRQ(ierr);
> > > >    PetscFunctionReturn(0);
> > > > #undef __FUNCT__
> > > > #define __FUNCT__ "MatMatSolve"
> > > >     MatMatSolve - Solves A X = B, given a factored matrix.
> > > >     Collective on Mat
> > > >     Input Parameters:
> > > > +  mat - the factored matrix
> > > > -  B - the right-hand-side matrix  (dense matrix)
> > > >     Output Parameter:
> > > > .  B - the result matrix (dense matrix)
> > > >     Notes:
> > > >     The matrices b and x cannot be the same.  I.e., one cannot
> > > >     call MatMatSolve(A,x,x).
> > > >     Notes:
> > > >     Most users should usually employ the simplified KSP interface
> for
> > > > linear solvers
> > > >     instead of working directly with matrix algebra routines such as
> > > > this.
> > > >     See, e.g., KSPCreate(). However KSP can only solve for one
> vector
> > > > (column of X)
> > > >     at a time.
> > > >     Level: developer
> > > >     Concepts: matrices^triangular solves
> > > > .seealso: MatMatSolveAdd(), MatMatSolveTranspose(),
> > > > MatMatSolveTransposeAdd(), MatLUFactor(), MatCholeskyFactor()
> > > > PetscErrorCode PETSCMAT_DLLEXPORT MatMatSolve(Mat A,Mat B,Mat X)
> > > >    PetscFunctionBegin;
> > > >    PetscValidHeaderSpecific(A,MAT_COOKIE,1);
> > > >    PetscValidType(A,1);
> > > >    PetscValidHeaderSpecific(B,MAT_COOKIE,2);
> > > >    PetscValidHeaderSpecific(X,MAT_COOKIE,3);
> > > >    PetscCheckSameComm(A,1,B,2);
> > > >    PetscCheckSameComm(A,1,X,3);
> > > >    if (X == B) SETERRQ(PETSC_ERR_ARG_IDN,"X and B must be different
> > > > matrices");
> > > >    if (!A->factor) SETERRQ(PETSC_ERR_ARG_WRONGSTATE,"Unfactored
> > > > matrix");
> > > >    if (A->cmap.N != X->rmap.N) SETERRQ2(PETSC_ERR_ARG_SIZ,"Mat A,Mat
> > > > X: global dim %D %D",A->cmap.N,X->rmap.N);
> > > >    if (A->rmap.N != B->rmap.N) SETERRQ2(PETSC_ERR_ARG_SIZ,"Mat A,Mat
> > > > B: global dim %D %D",A->rmap.N,B->rmap.N);
> > > >    if (A->rmap.n != B->rmap.n) SETERRQ2(PETSC_ERR_ARG_SIZ,"Mat A,Mat
> > > > B: local dim %D %D",A->rmap.n,B->rmap.n);
> > > >    if (!A->rmap.N && !A->cmap.N) PetscFunctionReturn(0);
> > > >    ierr = MatPreallocated(A);CHKERRQ(ierr);
> > > >    ierr = PetscLogEventBegin(MAT_MatSolve,A,B,X,0);CHKERRQ(ierr);
> > > >    if (!A->ops->matsolve) {
> > > >      ierr = PetscInfo1(A,"Mat type %s using basic MatMatSolve",
> > > > ((PetscObject)A)->type_name);CHKERRQ(ierr);
> > > >      ierr = MatMatSolve_Basic(A,B,X);CHKERRQ(ierr);
> > > >    } else {
> > > >      ierr = (*A->ops->matsolve)(A,B,X);CHKERRQ(ierr);
> > > >    ierr = PetscLogEventEnd(MAT_MatSolve,A,B,X,0);CHKERRQ(ierr);
> > > >    ierr = PetscObjectStateIncrease((PetscObject)X);CHKERRQ(ierr);
> > > > On Feb 29, 2008, at 6:46 PM, Yujie wrote:
> > > > > Hi, everyone
> > > > > I am considering to add a parallel MatMatSolve() into PETSc based
> on
> > > > > SuperLu_DIST or Spooles. If I want to use it like current
> sequential
> > > > > MatMatSolve() in the application codes, how to do it? Could you
> give
> > > > > me some examples about how to add a new function?
> > > > > thanks a lot.
> > > > > Regards,
> > > > > Yujie
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20080301/3e4da03c/attachment.htm>
