Error using BoomerAMG with eqns
Ben Tay zonexo at gmail.com
Mon Jun 9 21:46:50 CDT 2008
I tried to use BoomerAMG as the preconditioner. When I use ./a.out
-pc_type hypre -pc_hypre_type boomeramg, I got
KSP Object:
  type: richardson
    Richardson: damping factor=1
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
  left preconditioning
PC Object:
  type: hypre
    HYPRE BoomerAMG preconditioning
    HYPRE BoomerAMG: Cycle type V
    HYPRE BoomerAMG: Maximum number of levels 25
    HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
    HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
    HYPRE BoomerAMG: Threshold for strong coupling 0.25
    HYPRE BoomerAMG: Interpolation truncation factor 0
    HYPRE BoomerAMG: Interpolation: max elements per row 0
    HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
    HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
However, when I add the BoomerAMG into my code, I got
[3]PETSC ERROR:
[3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[3]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[3]PETSC
ERROR: or try http://valgrind.org on linux or man libgmalloc on Apple to
find memory corruption errors
[3]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
and run
[3]PETSC ERROR: to get more information on the crash.
[3]PETSC ERROR: --------------------- Error Message
[3]PETSC ERROR: Signal received!
[3]PETSC ERROR:
[3]PETSC ERROR: Petsc Release Version 2.3.3, Patch 8, Fri Nov 16
17:03:40 CST 2007 HG revision: 414581156e67e55c761739b0deb119f7590d0f4b
[3]PETSC ERROR: See docs/changes/index.html for recent updates.
[3]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[3]PETSC ERROR: See docs/index.html for manual pages.
[3]PETSC ERROR:
[3]PETSC ERROR: ./a.out on a atlas3-mp named atlas3-c36 by g0306332 Tue
Jun 10 10:36:34 2008
[3]PETSC ERROR: Libraries linked from
/nfs/home/enduser/g0306332/petsc-2.3.3-p8/lib/atlas3-mpi
[3]PETSC ERROR: Configure run at Tue Jan  8 22:22:08 2008
Here's part of my code:
call MatAssemblyBegin(A_mat_uv,MAT_FINAL_ASSEMBLY,ierr)
call MatAssemblyEnd(A_mat_uv,MAT_FINAL_ASSEMBLY,ierr)
call VecAssemblyBegin(b_rhs_uv,ierr)
call VecAssemblyEnd(b_rhs_uv,ierr)
call VecAssemblyBegin(xx_uv,ierr)
call VecAssemblyEnd(xx_uv,ierr)
call KSPSetOperators(ksp_uv,A_mat_uv,A_mat_uv,SAME_NONZERO_PATTERN,ierr)
call KSPGetPC(ksp_uv,pc_uv,ierr)
ksptype=KSPRICHARDSON
call KSPSetType(ksp_uv,ksptype,ierr)
call PCSetType(pc,'hypre',ierr)
call PCHYPRESetType(pc,'boomeramg',ierr)
call KSPSetFromOptions(ksp_uv,ierr)
tol=1.e-5
call
KSPSetTolerances(ksp_uv,tol,PETSC_DEFAULT_DOUBLE_PRECISION,PETSC_DEFAULT_DOUBLE_PRECISION,PETSC_DEFAULT_INTEGER,ierr)
call KSPSolve(ksp_uv,b_rhs_uv,xx_uv,ierr)
call KSPGetConvergedReason(ksp_uv,reason,ierr)
The matrix changes every timestep so I have to call the preconditioner
every time. So what did I do wrong? Btw, the matrix is A_mat_uv, RHS is
b_rhs_uv and the answer is xx_uv.
Thank you very much.
Regards.
